Anyone ever change the order of the dash gauges (4th gen)
Old May 10, 2007 | 04:20 AM
shutta's Avatar
Default Anyone ever change the order of the dash gauges (4th gen)
With my height, and where I have the steering wheel to drive, I can't see my directionals, much of the speedo, and a lot of times I am listening to music and drive liek my grandpa with the directionals on for miles..
Has anyone swapped the speedo/tach section with the CEL/brake/clock section?
I wanted to try to get a feel for how much work it will be to swap them out before I tear my dash apart and also if I'll need to extend the wires for each cluster
Old May 10, 2007 | 04:57 AM
preludestud11's Avatar
Default Re: Anyone ever change the order of the dash gauges (shutta)
have you tried a booster chair or something else? My sisters friend used to sit on pillows to get the extra boost in height.
Old May 10, 2007 | 07:36 AM
Hawkze_2.3's Avatar
It'll be a LOT of work if you can even do it. The 2 sides are setup very different, with the speedo/tach side being all 1 piece, and the fuel/temp/CEL side being severeal different layers bolted together. Plus the whole thing has a curve to it that might pose a problem...
Old May 11, 2007 | 04:23 AM
shutta's Avatar
hmm, I guess there isn't any other way o figure this out than to try it myself.. I know this sounds retarded, but all I really get pissed off about it the directionals, I could care less about speed and i'm rarely driving AT redline, so I might just splice into the lights that tell you when your blinker is on and run two single leds to blink in th center console under the stereo, that way I can definatly see them blinking anytime
Old May 11, 2007 | 04:31 AM
cb7tougeracer's Avatar
Default Re: (shutta)
try a aftermarket steering wheel some are smaller than stock
Old May 11, 2007 | 04:32 AM
95greenlude's Avatar
wow, you must be short....
you could try getting a JDM dash??
or maybe splicing some wires in and moving the blinker to the top of the gauge panel. and just having a couple of blinking LED's
darkd1gt
Jul 15, 2007 11:37 AM
bb4ninja
Feb 10, 2006 07:11 AM
Accord95Lxxx
Jun 16, 2005 05:31 AM
lodown414
Jul 17, 2002 01:41 PM
