Spool Up Times
Could everyone post what type of turbo (and kit) they have, and around the rpm where the turbo spools up to full boost. And how much boost you run thanx alot!! Just trying to get some info on turbo kits! I really appreciate your help! Nows your time to brag. I just want to get some raw figures! Thnx!
Rev Hard stage 2
t3/t04e
Hit full 7psi at 5000rpm and change (with stock exhaust)
Now with 3" I hit full around low 4000rpm area....
[Modified by shadowdawn, 10:52 PM 9/20/2002]
t3/t04e
Damn you dustin.... I wish my ish spooled that quick... big turbo + not that much lag + massive cfm =
Although having a stock exhaust I have the advantage of hearing the turbo SCREAM at low spool and its loud enough that you can hear it fairly far away... big turbos are plain sexy.
[Modified by shadowdawn, 4:15 PM 5/31/2002]
57 trim t04e / t3 stage 3 .63 a/r full boost 7psi @ 3700rpm on stock b18c1 w/ 3" dp and exhaust
Stupid 2.25" exhaust.....
I dont know if its because majestic turbo put a little bullet tip inside the compressor side. He said it would help spool faster, so maybe thats why.
Mine kicks in at 2800 RPM and makes 10 PSI at 3,700 RPM with a 2.5 inch downpipe and 2.5 exhaust, no cat convertor. 7.5 lb flywheel.
Its a t3/t4, .60 compressor a/r .63 exhaust a/r
And this is without a boost controller. So I'm sure it'll kick in even faster with a boost controller.
[Modified by BG Boost, 7:16 AM 6/1/2002]
boosting in final gear :D I'm auto so that would be 4th, and I boost looong in 4th on the freeway to get up hills... its almost unavoidable... of course I'm only talking 1-3psi max... unless I'm given her some gas...
Nothing wrong with boosting in 5th gear.
lol
lol
It's very hard to boost in 1st. Is that because my turbo is non-bb?
