sohc zc in ef9, wont start please help meeee!
Old May 10, 2007 | 12:01 AM
ef.love's Avatar
Default sohc zc in ef9, wont start please help meeee!
ok ive been at this for a couple days now. my car will not start. my dizzy is good my alternator is new my starter is cranking and i found out the problem but not 100% sure
the problem i think it is is that when i turn the key to the point where it shows the check engine light, battery, oil and brake lights i do not hear the fuel pump at all.
does this mean i need a new fuel pump or is my main relay bad??
please help its getting really annoying hahaha
Old May 10, 2007 | 07:16 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: sohc zc in ef9, wont start please help meeee! (ef.love)
Main relay.
Old May 10, 2007 | 07:29 AM
ef.love's Avatar
Default Re: sohc zc in ef9, wont start please help meeee! (wiZCo)
i checked the chiltons repair book and it told me to conect a wire from the fuel pump to the ignotion and i did that but not sure if i did it correctly. i also just took my friends main relay off his hatch and still no sighn of the fuel pumping
Old May 10, 2007 | 07:39 AM
wiZCo's Avatar
Stouts 'n' Scotch
Just reread your post, and I was wrong. The main relay would be faulty if it doesn't click after the CEL goes out. If you don't hear you fuel pump priming it's either the pump, a relay or the wiring. Find the hot lead for the fuel pump (I think it's a green/blk wire) and connect it to the ignition and see if it primes. If it doesn't I'd be willing to bet that the pump is dead.
Old May 10, 2007 | 08:07 AM
ef.love's Avatar
ok ill do that right now thanks
Old May 10, 2007 | 08:10 AM
ef.love's Avatar
yoyoyoyoyyoyoyoyoo!! i just found out the problem, turns out that me and my friend both had bad relays kuz we live right next to each other and one of our other friends came through and mine started right upp hahaha yo thanks for your help though man peace!!
Old May 10, 2007 | 08:11 AM
wiZCo's Avatar
Stouts 'n' Scotch
Glad you got it started.
d0wnShiFt
20
Dec 17, 2010 09:07 PM
ThatRHDstatus
Aug 8, 2010 08:05 AM
PatrickFrantz
Aug 21, 2008 05:53 AM
Lsweez
Jun 28, 2007 10:08 PM
fastaccord94lx
Sep 5, 2003 08:50 PM
