95 accord wagon back seat removal
i didnt know which forum to post this in, but this is an accord specific question.
i want to replace the carpet, and i need to remove the seat in order to unfasten
a few anchor points.---and still be able to put it back.
it is not in my manual or the archives
thanx for any help
thanx for any help
well im not sure if this will help considering my coupe is not the same but the way i do mine is you have to pull the backseat down...like you pull the lever in the trunk so you can push it down..and then there should be 2 bolts...once on each side...after that you can pull that part out...then theres just 2 little metal pieces that holds the bottom piece into your car you just have to wiggle it a little and slide it different ways..like i said im not sure if it will be the same but it could be ive never seen a wagons back seat so im not sure..maybe this will help some
jaimysessanna
Oct 22, 2015 06:40 AM
'08 b-rad
10
Dec 10, 2011 01:56 PM
ThumperAC
Oct 14, 2005 12:39 PM
