Comptech Header Fitment????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK »</TD></TR><TR><TD CLASS="quote">yeah should be no problem</TD></TR></TABLE>
Cool Thanks!
Cool Thanks!
I heard that since the B16 has a shorter deck height that it will hang about an inch lower. What do you mean by the length won't work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Power »</TD></TR><TR><TD CLASS="quote">I heard that since the B16 has a shorter deck height that it will hang about an inch lower. What do you mean by the length won't work?</TD></TR></TABLE>
he means it wont reach to the cat...youll have to get it custom extened which means welding has to be done...which isn't worth it haha.
It will reach the cat just fine. The length from front to back is exactly the same as the stock exhaust manifold. The only issue you'll have with the installation is the fact that the collector's flange is positioned at a different angle, so you'd need to modify the cat, use a custom one, or switch to an LS, ITR, or '00-01 GS-R cat.
IN2VTEC
May 22, 2003 09:47 PM
