skunks 2 cams!!!
Old May 9, 2007 | 06:45 PM
stock99si's Avatar
Default skunks 2 cams!!!
skunk 2 stage 2 cams for b series motor for 300 bux? can someone give me how much hp gain i would get outta my b16a2 with those cams installed?
Old May 9, 2007 | 06:47 PM
bmoua's Avatar
Default Re: skunks 2 cams!!! (stock99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">skunk 2 stage 2 cams for b series motor for 300 bux? can someone give me how much hp gain i would get outta my b16a2 with those cams installed?</TD></TR></TABLE>
good deal, you'll need to upgrade your vavletrains. what mods do you have? im guessing I/H/E. Overall gains should be at least 10hp or so...probably even more depending on mods on the motor.
Old May 9, 2007 | 06:49 PM
stock99si's Avatar
Default Re: skunks 2 cams!!! (bmoua)
i got i/full exhaust/ stock headers
how much is it to upgrade a valve train?
and what happens if i dont
Old May 9, 2007 | 06:52 PM
doood's Avatar
been there done that
dont upgrade valvetrain and your valves and pistons will say hello to each other. gains are 10-20whp depending on the entire setup. these cams will really shine when you up the compression as well.
Old May 9, 2007 | 06:53 PM
bmoua's Avatar
Default Re: skunks 2 cams!!! (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">dont upgrade valvetrain and your valves and pistons will say hello to each other. gains are 10-20whp depending on the entire setup. these cams will really shine when you up the compression as well.</TD></TR></TABLE>
its not really required to upgrade the vavletrains but its recommended...i'd upgrade.
Old May 9, 2007 | 07:04 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">its not really required to upgrade the vavletrains but its recommended...i'd upgrade. </TD></TR></TABLE>
even skunk2 recommends valvetrain with the stage 2's and up. you'd be a fool not to.
Old May 9, 2007 | 07:08 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">i got i/full exhaust/ stock headers
You have one header.
Cost to upgrade valve train depends entirely on which components you choose and whether or not you can do the work yourself, but count on ~$200 for springs, ~$250-300 for valves, ~$100 for retainers, (plus new valve seals & locks if you want to build it right)...
If you don't, you'll very likely have piston-to-valve clearance issues which usually result in a catastrophic engine failure...
HitF8
Jun 3, 2010 11:13 AM
adam00
Aug 13, 2008 05:24 AM
EgSiCknEsS
Apr 3, 2007 09:16 PM
EMwUnDuH
Aug 18, 2006 08:24 AM
9341civic
Jul 1, 2005 02:59 AM
