Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
quick question
Old May 9, 2007 | 06:02 PM
yuning83's Avatar
Default quick question
When I put on new rims with tires do I need to do any alignment? I'm doing it myself so I'm curious. Some of my friends says I need to do alignment so I don't mess up the car. Then again, they aint'no expert so... lol
Old May 9, 2007 | 06:04 PM
Nighthawk R18's Avatar
no need for alignment if its only rims and tires. however yes when you get lowered
Old May 9, 2007 | 06:06 PM
yuning83's Avatar
Default Re: (Nighthawk R18)
oh cool. what about going from 16 to 17 or 18 inch, anything special besides getting them on the car?
Old May 9, 2007 | 06:11 PM
Default Re: (yuning83)
if you get bigger or smaller rims you may need alignment. but it wont be absolutely neccessary after some new rims if they are the same size as the stock.
Old May 9, 2007 | 06:23 PM
kenw's Avatar
It isn't rquired if all you do is remove and replace the tires/wheels. However if you replace any suspension components it is required.
However, as a rule I usually have a 4 whel alignment done after getting new tires if t has been awhile. It is cheap compared to 4 tires and will help them last longer. If you are spending that much money (new wheels and tires), an extra $80 is pretty smart.
Old May 9, 2007 | 08:36 PM
yuning83's Avatar
Default Re: quick question (yuning83)
What does balancing the tire after getting on the the rims mean? Is this something I can do it myself?
Old May 9, 2007 | 08:51 PM
20strong's Avatar
When they balance a tire they place weight in positions on the wheel to offset the imperfection of the tire and wheel. Basically it makes them not wobble at speed because there is to much weight in one spot.
Old May 9, 2007 | 09:00 PM
Default Re: (20strong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20strong &raquo;</TD></TR><TR><TD CLASS="quote">When they balance a tire they place weight in positions on the wheel to offset the imperfection of the tire and wheel. Basically it makes them not wobble at speed because there is to much weight in one spot. </TD></TR></TABLE>
in short, you cant balance it yourself you need one of those machines that pepboys have.
Old May 9, 2007 | 09:04 PM
20strong's Avatar
^^ Thanks
Old May 10, 2007 | 10:45 AM
Hellzcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuning83 &raquo;</TD></TR><TR><TD CLASS="quote">What does balancing the tire after getting on the the rims mean? Is this something I can do it myself? </TD></TR></TABLE>
Balance = Balance the weight of the wheel. Rims and tires are not perfectly uniform. At speed, that lack of uniformity can cause wheel shimmy, vibrations, or worse. Balancing the wheel corrects for the uniformity by placing weights on the rims (both outside and inside). These weights allow the wheel to spin true at speed.
If you have a bubble balance you can, but it really is not a good way to balance your wheels. High speed spin balance is what you need and you need special equipment. Most gas stations with a shop have a high speed balance machine
So to answer your question, no, you can't balance the wheels yourself.
toshko321
Jul 26, 2009 05:14 PM
Morasso
Jan 31, 2007 09:43 AM
biggusf
Aug 14, 2006 02:26 PM
TurboEM1
Suspension & Brakes
Nov 14, 2005 03:59 PM
digitalh3lix
May 7, 2005 09:43 AM
