Halfshafts
Old May 9, 2007 | 05:51 PM
clutchmaster2005's Avatar
Default Halfshafts
when replacing a clutch... do you only need to remove one halfshaft to drop tranny, or remove both?
Old May 9, 2007 | 06:10 PM
91ed9's Avatar
Default Re: Halfshafts (clutchmaster2005)
you gotta remove both bc you need to get the intermediate shaft out
Slurp56's Avatar
well, you should only have 1 half shaft and 2 axles.
To drop the tranny, you'll need to remove both axles and the halfshaft.
If you dont have a halfshaft, then you have only 2 axles.
Old May 9, 2007 | 06:27 PM
whats the difference between a halfshaft and a axle. is the shorter shaft a half shaft, and the longer one the axle? they both have cv joints (inner and outer) on them. whats the difference?
Reelizmpro
11
Sep 8, 2005 02:08 PM
scratchy
Apr 10, 2004 01:46 PM
sabertooth
Jan 21, 2004 06:27 PM
NINJASPY
Sep 19, 2003 02:57 PM
Rob :190:
Feb 22, 2003 08:44 AM
