2 wheel steer conversion done.. a few questions..
Hi guys, I recently finished off my 2 wheel steer conversion on my 4th gen prelude, but I've got a question. There seems to be some movement (left and right) of the wheel. The movement seems to be coming from the rear tie bars.
Can anyone tell me if this is normal?
I'm assuming it's not and it probably the bush that needs changing, can anyone confirm this ?
Thanks a lot!
Thanks a lot!
He's talking about 4ws guys. Looks like a 4th gen in his pic...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude »</TD></TR><TR><TD CLASS="quote">There seems to be some movement (left and right) of the wheel. The movement seems to be coming from the rear tie bars.
Can anyone tell me if this is normal?</TD></TR></TABLE>
Since the rear wheels are in no way connected to the power steering system in the 4th gens there's no way the rear wheels can move the steering wheel. Have you gotten an alignment recently? If not I'd do that first.
what exactly did you do to "convert" it back from 4ws? Di dyou replace the whoel rear crossmember? If it's just play in the wheel check the ball joints or the wheel bearings.
are th wheels just wobbling, or moving around like they would when you turned th steering wheel with 4ws?
