h22 block busted in front.
Old May 9, 2007 | 11:16 AM
preludefien
Guest
Posts: n/a
Default h22 block busted in front.
driving down the highway the other day. i hear this rubbing/grinding noise thinking that it was a belt. i hear something pop and i immediately turn the car off and coast to the side lane. i thought it was a broke timming belt. but upon inspection today i say a big chunk of my block stuck in my radiator. take a look and its a whole the size of my fist in the front of my block and i think i see the crank and a rod hanging out. so my question is what could have caused this and is there anything that i need to check when i swap the block out. do i need to check the head or anything like that. o before this happened my car was misfiring but not all that bad.
Old May 9, 2007 | 11:24 AM
mgags7's Avatar
Damn chris that noise was the worst case I thought it could possibly be, rod knock.
So you threw a rod....wow that sucks incredibly.
When the head comes off you just need to look and make sure that the rod you threw didn't let the piston smash into the combustion chamber and ruin that or the valves.
PM me though, I may be able to find you a block.
Old May 9, 2007 | 11:33 AM
cleve's Avatar
Default Re: h22 block busted in front. (preludefien)
how bad of a misfire or was it more of a back fire where you are running to rich cause i am having that problem right now. i have never heard of the block breaking off in a chunk like this... at which cylinder was this?
Old May 9, 2007 | 11:34 AM
preludefien
Guest
Posts: n/a
Default Re: (mgags7)
haha tell me about it...the worse case is always in my favor. aye that guy that you said does the import part. you think he could hook me up with a block..
Old May 9, 2007 | 11:37 AM
preludefien
Guest
Posts: n/a
Default Re: (preludefien)
looks like the 2nd one..
hoffdaddy
Engine Machining & Assembly
Jul 27, 2015 01:02 AM
sewell94
Jul 28, 2007 12:01 AM
self_made
Sep 24, 2006 04:40 PM
mrS2K
Honda S2000
May 5, 2005 11:31 PM
WICKED2
Feb 20, 2002 12:54 PM
