rumbling sound on left turns
Old May 9, 2007 | 10:39 AM
ekferio's Avatar
Default rumbling sound on left turns
Everytime my car turns left and i let off the gas, i get this loud deep rumbling noise under the car. I had a mugen exhaust put in 2 months ago but nothing seems to be hitting it when i checked. Is it possible that there's a defect inside the muffler or resonator? If not my exhaust, what else can it be? This is a really weird problem because the noise is on left turns only.
Old May 10, 2007 | 11:36 AM
all boost's Avatar
Default Re: rumbling sound on left turns (ekferio)
Get under your car and check your axles. Look for cv boot rips and grease! Sounds like your cv joints are going out! Common problem sound when turning! Hope that helps?
Old May 10, 2007 | 11:39 AM
Damon Reeves's Avatar
Either axles or your struts?
Old May 10, 2007 | 11:48 AM
walker111's Avatar
Default Re: rumbling sound on left turns (Damon Reeves)
Or wheel bearing. Jack up the front and shake the wheel back and forth, if you have play....time for new bearings.
Old May 10, 2007 | 02:16 PM
ekferio's Avatar
Default Re: rumbling sound on left turns (walker111)
not a wheel bearing problem, i already checked. i thought CV joint makes clicking sounds? this is more like a rattling, rumbling and buzzing. i can feel the car vibrates when it happens. Seems to have an increase in road noise too
Old May 10, 2007 | 02:20 PM
all boost's Avatar
try checking your engine mounts and exhaust hanger mounts?
Old May 10, 2007 | 02:26 PM
migs's Avatar
Default Re: rumbling sound on left turns (all boost)
Sounds like wheel bearings to me. How did you test the bearings?
Old May 10, 2007 | 02:32 PM
ekferio's Avatar
Default Re: rumbling sound on left turns (migs)
jacked the wheel up and grabbed it on the top & bottom & shoke it. This rattle noise is louder after letting off the gas and more apparent above 30mph
Old May 15, 2007 | 05:53 PM
ekferio's Avatar
took it to acura, they think one of the motor mounts needs to be replaced....i'm still waiting on parts. Can a bad motor mount makes a knocking sound too? i think i'm starting to hear a bit of knockings sometimes when i shift and also turning left.
Old May 15, 2007 | 07:03 PM
migs's Avatar
Absolutely it can knock.
sedorbrian
Feb 1, 2012 01:53 AM
ritz7
11
Dec 19, 2010 03:22 PM
bushtucker
12
Jul 28, 2010 11:50 AM
spender1326
May 31, 2005 05:27 PM
631 Teggy
Dec 29, 2003 07:55 PM
