03 Accord EXL 4cyl = Horrible gas mileage < 18 mpg
Old May 9, 2007 | 07:59 AM
92HB_HB's Avatar
Default 03 Accord EXL 4cyl = Horrible gas mileage < 18 mpg
I just bought an 03 accord exl, it looks great but the gas mileage on it sucks *****.. It has about 81,000 miles
I just filled and topped it off w/ about 12 gallons and was only on around 230 miles. Verry poor in my opinion.. my 07 camry gets about 350 city driving where as this accord may get about 260 tops before the needle gets to "E".
I just changed the NGK platnium spark plugs which look to be the originals w/ some bosch platniums since the auto store didn't have any NGK's in stock..
I hope the new plugs will help w/ gas mileage as its worse than a 6 cylnder right now..
the previous owners also mentioned that the 02 was recently changed and the car isn't throwing any CEL's either.. The air filter was also checked and seems to be brand new as well..
So what else could be causing this crappy gas mileage??
Old May 9, 2007 | 08:34 AM
Patman's Avatar
it seems like it would almost have to be the 02 sensor, they could have touched it and ruined the sensor
Old May 9, 2007 | 08:41 AM
Cannon Man's Avatar
I forget which plugs are ideal for accords but as far as I know the platinums aren't them. I've also heard from people in this forum that you should never top off the tank. Wouldn't hurt to try that once and see if it improves anything.
Old May 9, 2007 | 09:19 AM
92HB_HB's Avatar
Default Re: (Cannon Man)
let me clarify.. i stopped when the pump stopped..
if and when you find out the ideal plug, please let me know.. thanks..
Old May 9, 2007 | 09:27 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The NGK OE Laser Iridiums - IZFR6K11 are the recommended plugs for the 2003 Accord L4.
Old May 9, 2007 | 03:20 PM
Turbowa's Avatar
Default Re: (92HB_HB)
Some things not right here. you said that you filled the tank up with 12gal. of fuel. You should have been able to put ALOT more in there. The car have a 17.1 gal. fuel tank. Even if you drove with the gas light on for a little bit you should still be able to put just over 15gal's in. Also how are you cal. that milage. The correct way is to fill up the tank, before you even start the car set one of your tipometers to zero, drive till you need gas again. Then when you fill up the tank take the number of gallens and divide that into the milage that you have recorded. You will want to do this for atleast one more time. Then average them together. This will be the best way to figure you milage out.
Old May 9, 2007 | 07:34 PM
92HB_HB's Avatar
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">The NGK OE Laser Iridiums - IZFR6K11 are the recommended plugs for the 2003 Accord L4.</TD></TR></TABLE>
Dam advance auto parts didn't have these in stock..
Old May 9, 2007 | 07:36 PM
92HB_HB's Avatar
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa &raquo;</TD></TR><TR><TD CLASS="quote">Some things not right here. you said that you filled the tank up with 12gal. of fuel. You should have been able to put ALOT more in there. The car have a 17.1 gal. fuel tank. Even if you drove with the gas light on for a little bit you should still be able to put just over 15gal's in. Also how are you cal. that milage. The correct way is to fill up the tank, before you even start the car set one of your tipometers to zero, drive till you need gas again. Then when you fill up the tank take the number of gallens and divide that into the milage that you have recorded. You will want to do this for atleast one more time. Then average them together. This will be the best way to figure you milage out.</TD></TR></TABLE>
NO.. I filled up after getting 230 miles to see how much it would take to fill up the tank again.. and I got about 12 gallons in before the pump stopped..
Old Jul 25, 2007 | 02:14 PM
NGUSPEED's Avatar
I have an 03 Accord EX 4cyl and Im getting 380mi, at 15.xx gallons. The gas light comes on around 320mi. My friend has an 04 EX 5spd and he claims 27-30MPG. I cannot figure out why I cant come close.
Old Jul 25, 2007 | 04:59 PM
CBL9's Avatar
Default Re: (NGUSPEED)
On my 06 EX 5spd, I get around 32-34 (I do mostly highway)
Old Jul 25, 2007 | 08:17 PM
361 accord's Avatar
Default Re: (CBL9)
damn thats bad , op i get 24 city, 36 highway doing around 72
Old Jul 26, 2007 | 04:13 AM
msedacca's Avatar
Default Re: (361 accord)
That's really bad, driving to and from work with a turbo sucking in 11.1 AFR at max boost and I still get 24+mpg with mostly traffic highway conditions. I always pull at least 300 miles out of 13 gallons. And my MPG isn't that much worse now than when it was pre-turbo, because I don't run around maxing out every gear, which took about a month to get over. Sometimes it can be something weird, but try two more tanks, and if its the same problem then you should look for a solution, but don't go to a dealer cause they're retarded.
zedjr
Feb 16, 2013 06:08 AM
dman81
Jan 12, 2010 11:47 AM
A Tribe Called Honda
Oct 2, 2008 05:40 PM
rideredorgohome
Jan 26, 2005 11:56 AM
NiBlazed
Oct 26, 2004 07:07 PM
