f20 compatiblity with 02 accord coupe for swap
Old May 9, 2007 | 04:26 AM
gustavito1986's Avatar
Default f20??
i got an 02 accord coupe and was wondering if this would fit in it ???
http://www.hmotorsonline.com/s...30013
it woul be something diff than a h22
Old May 9, 2007 | 04:38 AM
BlkChryKord's Avatar
Link didn't work for me so I'm assuming its for the F20B.
Yes it'll swap in, its OBD2, and it should drop in and be wired up like an H22. Although you are losing .3L of displacement.
Old May 9, 2007 | 04:52 AM
sleepy96's Avatar
Default Re: f20?? (gustavito1986)
The link doesn't work anymore, but why the hell would you want to do that? It would be expensive, for no real gain. It would be like replacing a 20yr old chick for a 40yr old, slower with more baggage.
edit-oops, let me answer your question... yes it will work.
Old May 9, 2007 | 05:44 AM
Default Re: f20?? (sleepy96)
that should work now im hoping . well one its cheaper than the h22 and the specs dont seem that bad
Old May 9, 2007 | 06:15 AM
sleepy96's Avatar
Oops, yeah that would probably work alright. ignore my other post, there is a sohc variant of that engine. I was afraid you were talking about that one, brain fart. F series engines are nice engines, cheaper to get than an H22, and the handle crazy boost. I say go for it, it should bolt in, you will probably have to get new engine mounts.
Old May 9, 2007 | 02:46 PM
my friend was tellin me since its euro that it wont jus drop in ..
Old May 9, 2007 | 06:35 PM
Your friend is on crack.
Old May 10, 2007 | 05:27 AM
Default Re: f20?? (BlkChryKord)
lol well he said that cause its all euro. well would it drop right in??? cause i might look into the f20
Old May 10, 2007 | 05:45 AM
Other than what I said previous, it will drop right in.
Edit: I forgot to mention you may have some trouble w/ the driver's side motor mount. I've never seen an F20B swapped in but I'm assuming it uses simliar mounts to the H22.
Old May 10, 2007 | 06:14 AM
Default Re: (BlkChryKord)
lol thanks!
lilbluecar89
Dec 17, 2010 07:18 AM
b18c_Ek101
Oct 5, 2010 07:33 AM
one2chi(for now)
Jun 10, 2003 07:19 PM
nightryder21
Apr 1, 2003 09:37 AM
