I Need Help Really BAD please read.... NEED ADVICE
like a hour ago i broke my bottom bolt to my transmission mount. Im just making sure of if you can just change the outter case part\. Ive seen poeple take the gears out with the case with it and it was just the outer part that the starter bolts to and the back bracket.. I hope this is making since. Are f22 and h22 transmission the same. because i was going to tkae the gear case out and put it on the f22 case. ... please help
Guest
Posts: n/a
dude learn to spell and form actual sentences. Anyway, you can take the bell housing off, if the bolt is broken inside the block your going to need to drill and tap it out of there. That is a pain in the anus my friend...gl with that.
