crx harness replacement
Old May 8, 2007 | 08:55 PM
hayn420's Avatar
Default crx harness replacement
i got a 88 crx hf with a zc swap and i wanted to sell the motor with the harness so my question is can i get a 88-91 crx hf of si harness and replace the one that i had in the car
Old May 9, 2007 | 12:04 AM
yz125rider21's Avatar
yes you have to have a ef or si harness 88-89 if you have one those years or 90-91 cause there are a couple clips diff...besides that you be good to go...as long as your still obd-0
Old May 9, 2007 | 07:27 AM
jlicrx's Avatar
Default Re: crx harness replacement (hayn420)
you will need only the 88 or 89 HF engine harness - Si harnesses and 90-91 HF harnesses are not the same as 88-89 HF - why let the harness go with the engine - unless the buyer has 88 or 89 HF, he won't be able to use that harness
Old May 9, 2007 | 08:13 AM
wiZCo's Avatar
Stouts 'n' Scotch
Plus the wiring conversion for a ZC is very simple. There's no need to sell the entire harness IMO, it would just create more headaches.
Old May 10, 2007 | 07:31 PM
D_301crxman's Avatar
Default Re: (wiZCo)
yea he right y not sell just motor or engine it self no nedd to sell hardness
94delsol-b16a
Dec 12, 2009 11:32 AM
hondaex99
Oct 29, 2009 09:19 PM
The Tea-father
Oct 14, 2006 07:29 AM
deftones0817
21
Feb 21, 2004 01:27 PM
