195-60-r15 on 15x6 Honda wheels that I thought were 15x5.5 Will I be OK?
Old May 8, 2007 | 08:39 PM
CBL9's Avatar
Default 195-60-r15 on 15x6 Honda wheels that I thought were 15x5.5 Will I be OK?
I really thought these wheels were 5.5" wide, today I got the new tires from UPS and I randomly looked at the back of the wheel and the wheel was 15x6, son of a bitch. The stock tire size for the 15x6 wheel is 205-60-r15. I know the new tires I bought are simply 10mm smaller, but is that 10mm too small? I really hope I am OK here, otherwise I just lost some bones....
Old May 8, 2007 | 08:58 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 195-60-r15 on 15x6 Honda wheels that I thought were 15x5.5 Will I be OK? (CBL9)
Here is a site to compare the tire sizes:
http://www.1010tires.com/TireSizeCalculator.asp
If the stock tire size was 206/60/15, and you switched to a 196/60/15, I believe your speedometer/odometer might become slightly off; but there shouldn't be any fitment problems.
Old May 8, 2007 | 09:03 PM
CBL9's Avatar
To Clarify
I have a 1993 Accord Stock rims 15x5.5 with stock 195-60-r15 Tires, the tires were bad and the rims curbed so I sold them for cheap.
I also have a 1995 Accord V6 with 15x6 rims stock 205-60-r15 tires. I upgraded to 18's on the 1995 (I know I am a ricer) and have the old 15x6 rims left from the 1995.
So I thought hey I will buy new tires for the 1995 wheels and put them on the 1993. So I bought 195-60-r15 tires for my 1993 Accord assuming the rims on the 1995 were also 15x5.5, and I was wrong.
I just want to know if the 195s are too narrow vs the 205s for the 15x6 rim. I drive a lot of highway 90 miles round trip to work 5 days a week and do not want any uneccesary things happening.
Old May 8, 2007 | 11:40 PM
pos_cd5's Avatar
Default Re: (CBL9)
you'll be fine. 195 wide tire will fit on a 6inch no problem, people stretch 195s onto 7inch wide wheels nowadays. 195/60 comapred to the stock 205/60 is the 195/60 is shorter in diameter by .5 inch. your speedometer will read only 1.9% faster, so its nothing to worry about.
Old May 9, 2007 | 03:08 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">195/60 comapred to the stock 205/60 is the 195/60 is shorter in diameter by .5 inch. your speedometer will read only 1.9% faster, so its nothing to worry about.</TD></TR></TABLE>
not that it really matters in this case but his speedometer won't be off at all.
you are comparing the stock tire (205/60/15) that came on the rim from the 95 AV6. Since he is going to be using 195/60/15 and the stock tire that came on the 93 Accord was a 195/60/15 there won't be any change to the speedometer or anything.
Old May 9, 2007 | 03:54 AM
CBL9's Avatar
Default Re: (TouringAccord)
Thanks Guys. I just do not want a problem with safety, just for the fact I am cruising at 70-75ish for 50 miles outta my commute each day on the NYS Thruway.
Old May 9, 2007 | 09:02 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
you are comparing the stock tire (205/60/15) that came on the rim from the 95 AV6. Since he is going to be using 195/60/15 and the stock tire that came on the 93 Accord was a 195/60/15 there won't be any change to the speedometer or anything.</TD></TR></TABLE>
you shut your dirty little mouth, touringaccord!
haha, j/p. i didnt notice that part, thanks for pointing it out.
Old May 10, 2007 | 03:20 AM
H-T Order of Merit
haha
Edward Moneo
Dec 18, 2012 10:37 AM
junkit54
Jan 7, 2010 06:15 AM
Delano5050
Mar 25, 2007 05:55 PM
1accord
Jan 5, 2007 02:49 PM
jond
Jun 22, 2002 04:21 PM
