So I changed my alternator.....
Old May 8, 2007 | 06:47 PM
NtheWorks's Avatar
Default So I changed my alternator.....
Something was squeaking before I did it so I decided to go ahead and replace the belt too.....and now it squeals LOUD. The belt I took off of it was basically mangled on one side. Could this be a bad pulley now? And if so, how do I tell which one squeals like a banshee?
(H22a Prelude)
All positive feedback is appreciated.
Old May 8, 2007 | 07:15 PM
Hawkze_2.3's Avatar
Default Re: So I changed my alternator..... (NtheWorks)
First thing you need to do is tighten it really good and see if that gets rid of the squeal...
Old May 8, 2007 | 07:27 PM
yOnKiNaToR's Avatar
Default Re: So I changed my alternator..... (Hawkze_2.3)
usually a quiet squeal is because the belt is too loose while a very loud squeal is because the belt is way to tight.
Old May 8, 2007 | 07:31 PM
Hawkze_2.3's Avatar
Default Re: So I changed my alternator..... (yOnKiNaToR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOnKiNaToR &raquo;</TD></TR><TR><TD CLASS="quote">usually a quiet squeal is because the belt is too loose while a very loud squeal is because the belt is way to tight.</TD></TR></TABLE>
Yes, true true, you definately don't want it too tight. I guess I meant to say make sure it's tightened correctly...you should be able to twist the belt 90 degrees or so.
Old May 9, 2007 | 05:17 AM
NtheWorks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, true true, you definately don't want it too tight. I guess I meant to say make sure it's tightened correctly...you should be able to twist the belt 90 degrees or so.</TD></TR></TABLE>
Oh. lol I kinda of tightened it as tight as it would go.....mah bad.
That's why I'm a noob
vinceiscoo
Sep 16, 2008 11:20 PM
kenny24
Aug 30, 2005 03:52 AM
blackccoupe
Sep 23, 2003 03:00 PM
andrewasf77
Jul 10, 2003 08:24 PM
keithv
Aug 7, 2002 04:40 AM
