REAR DISK BREAK CONVERSION??????
Old May 8, 2007 | 06:12 PM
ROTEN EF8's Avatar
Default REAR DISK BREAK CONVERSION??????
I WAS WONDERING IF YOU DO THE REAR DISK CON ON A CRX DX BO YOU NEED TO UPGRADE SI MASTERCYLINDER???
Old May 8, 2007 | 06:15 PM
92civicfreak's Avatar
1. search... there are 10,000 threads on this already...
2. you dont NEED it, but the SI or DA brake booster/mater cylender & 4040 prop valve are recomended
Old May 8, 2007 | 06:35 PM
Mr_CRX's Avatar
Default Re: REAR DISK BREAK CONVERSION?????? (ROTEN EF8)
If you upgrade from drums to stock sized rear discs and keep your stock CRX DX front brakes, I would recommend using the 2040 proportioning valve to transfer the correct amount of fluid between the front and rear.
THEhomelessONE
Sep 3, 2018 05:55 PM
eg8ynot
Nov 6, 2008 04:43 PM
crxfreak1117
Sep 29, 2006 03:27 PM
EGhatched
10
Mar 31, 2004 08:45 AM
V8bait44
Mar 26, 2004 02:33 PM
