camber kit
i changed my suspention to integra and i even put a adjustable camber kit n pushed them as far out as they can n the wheels still split wat the hell am i sopose 2 do
whoa wait a minute, did you change the lower control arms to the integras', if you did YOUR WRONG! change your lower control arms to the civics' and you'll be golden.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99civic »</TD></TR><TR><TD CLASS="quote">whoa wait a minute, did you change the lower control arms to the integras', if you did YOUR WRONG! change your lower control arms to the civics' and you'll be golden.
what are you talking about? 94-01 integra LCAs are same as 92-95 civic Si LCAs...i personally went with 1992 JDM Civic SiR LCA+knuckle, which is also identical
</TD></TR></TABLE>what are you talking about? 94-01 integra LCAs are same as 92-95 civic Si LCAs...i personally went with 1992 JDM Civic SiR LCA+knuckle, which is also identical
magnumdad
Suspension & Brakes
May 4, 2005 08:48 AM
