b18 code 13 and 8
Code 8 is TDC, thats top dead center sensor inside the dizzy. Replace dizzy with known working one, if that doesn't fix it, check wiring to your harness (you didn't mention any OBD or what your setup was, not cool).
Code 13 is is Atmospheric Pressure Sensor. No clue on how to fix it. More then likely a bad sensor or bad wiring.
Locking this because you have this thread https://honda-tech.com/zerothread/1977235 and your questions are being answered there.
