Compression Test Done..
Old May 8, 2007 | 04:28 PM
guero2craze's Avatar
Default Compression Test Done..
The results that i acquired were after 7cranks...
Cylinders Readings
#1 - 250
#2 - 237
#3 - 250
#4 - 248
Is this good for a gsr?
The motor is a 94 with 113k miles
Any feedback is welcomed...
Old May 8, 2007 | 07:23 PM
suzawa94's Avatar
Default Re: Compression Test Done.. (guero2craze)
seems normal to me. to be accurate you would have to reference those numbers to an oem manual. from there they might give you a spec like 10-15% from 250 psi or something like that.
reason for compression test?
Old May 8, 2007 | 08:09 PM
numbnuts22715's Avatar
yeah, its not bad.
as a general rule of thumb, anything greater than a 20 psi difference can mean something is wrong.
yours look spretty good
Old May 8, 2007 | 08:14 PM
suzawa94's Avatar
Default Re: Compression Test Done.. (suzawa94)
why i ask why you're doing a compression test if you're having any engine problems. SOMETIMES a compression test is not the most accurate way of diagnosing engine problems.
Old May 8, 2007 | 08:15 PM
he may just be doing it to find out how healthy his motor is...
A lot of people do that.
Old May 8, 2007 | 08:28 PM
suzawa94's Avatar
Default Re: (numbnuts22715)
yeah, but if you're not having any drivability problems why bother? so how if one of the cylinders falls slightly below spec, but still runs ok? does that justify a rebuild? or a teardown for inspection?
Old May 8, 2007 | 08:44 PM
Lewy. Dee Ayy's Avatar
Default Re: (suzawa94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, but if you're not having any drivability problems why bother? so how if one of the cylinders falls slightly below spec, but still runs ok? does that justify a rebuild? or a teardown for inspection?</TD></TR></TABLE>
maybe hes going to boost it or something..so hes doing a compression test to make sure everything is ok with his motor..
jeez get off his back..
im doing a compression test cause my car is blowing blue smoke at times..cause i want to do 402 cams..but if my rings are bad..why bother?...ill just wait till i get a new motor..or rebuild
Catch my drift buddy ol pal.
Old May 8, 2007 | 09:03 PM
Default Re:
The reason of doing a compression test was just to see how healthy my engine was...and Also because i was planning on slapping a t3/t4 turbo on the gsr, just to get those extra ponies
Old May 8, 2007 | 09:15 PM
slammed95dc2's Avatar
pretty good man
Default Re: Re: (guero2craze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guero2craze &raquo;</TD></TR><TR><TD CLASS="quote">The reason of doing a compression test was just to see how healthy my engine was...and Also because i was planning on slapping a t3/t4 turbo on the gsr, just to get those extra ponies </TD></TR></TABLE>
see..i was correct
76 camaro car
Apr 20, 2017 04:47 AM
DAprojectTuRtle
May 1, 2010 02:03 PM
Belarus
Apr 2, 2010 03:01 AM
