Tire size for 16 x 7 wheels on a Teg
Old May 8, 2007 | 03:56 PM
GSR2001's Avatar
Default Tire size for 16 x 7 wheels on a Teg
I'm getting 16x7 wheels with +40 offset for my Teg.
(1)205/45/16 or (2) 215/45/16 Falkens
My drop is less than two inches.
Here is my car as it sits now with 205/55/15s.
Please post pics with tire & rim size.
Thanks
Old May 8, 2007 | 04:01 PM
DaveSi677's Avatar
Default Re: Tire size for 16 x 7 wheels on a Teg (GSR2001)
Either one is fine. Get the cheaper one!
You won't see any difference in performance between the 2!
Old May 8, 2007 | 04:07 PM
GSR2001's Avatar
Default Re: Tire size for 16 x 7 wheels on a Teg (DaveSi677)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveSi677 &raquo;</TD></TR><TR><TD CLASS="quote">Either one is fine. Get the cheaper one!
You won't see any difference in performance between the 2!</TD></TR></TABLE>
I'm worry about them rubbing or the side wall being too high or too low. I used to have 17s with 205/40/17s.
Old May 8, 2007 | 04:10 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR2001 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm worry about them rubbing. I used to have 17s with 205/40/17s.</TD></TR></TABLE>
If a 215/45-16 rubs, then you might have the wrong offset on your wheels.
When I was tucking tire (sigh, never do that again) with 205/45-16s (very little difference in size between a 215/45-16, and both are more or less correct for an Integra), I only had rubbing in the front at full lock, with considerable suspension bump. Meaning, I only rubbed when turning into a driveway with the steering at full lock and extra people in the car.
I also had no rubbing issues during autocross, even that low. However, the car's balance was horrible with the front sitting on the bumpstops like that.
Old May 8, 2007 | 04:30 PM
GSR2001's Avatar
Default Re: Tire size for 16 x 7 wheels on a Teg (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I also had no rubbing issues during autocross, even that low. However, the car's balance was horrible with the front sitting on the bumpstops like that.</TD></TR></TABLE>
THANKS!
Anyhow I would like to see some pics!
Old May 8, 2007 | 07:30 PM
nsxtasy's Avatar
H-T Order of Merit
Neither size will rub, as long as your wheels have the proper offset.
However, 205/55-15 is too big, about 2 percent larger diameter than the stock tire size. Both 205/45-16 and 215/45-16 are less than 1 percent different from stock.
Old May 11, 2007 | 02:23 PM
GSR2001's Avatar
Default Re: Tire size for 16 x 7 wheels on a Teg (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Neither size will rub, as long as your wheels have the proper offset.
Switching to 205/50/15 next week! The order was done by phone so I told them that they mess up the order.
Old May 11, 2007 | 09:09 PM
Leo C's Avatar
Night Owl
I would go with 205/45/16, for the simple reason that tires are more readily available and cheaper in that size.
And fyi, that appears to be a 99-00 civic si/ ctr lip on your teg.
Modified by Leo C. at 10:35 PM 5/11/2007
Old May 12, 2007 | 09:18 PM
GSR2001's Avatar
Default Re: Tire size for 16 x 7 wheels on a Teg (Leo C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo C. &raquo;</TD></TR><TR><TD CLASS="quote">And fyi, that appears to be a 99-00 civic si/ ctr lip on your teg.
No **** Sherlock, REALLY!!!!!!
It is a CTR style Lip.
CTR = Civic Type R
Old May 13, 2007 | 02:21 AM
Leo C's Avatar
Night Owl
[img]https://i92.photobucket.com/albums/l26/paposalsa/Miscellanous/Captain_obvious.jpg[/mg]
CTR = Civic Type R</TD></TR></TABLE>
Heh I don't know why the picture was necessary. Just pointing out that the 99-00 SI/ CTR lip on your car was intended for a different make/model. That seemed to have rubbed you the wrong way.
An OEM or replica ITR lip would be a far better choice. But I guess like the 205/55/15 tires, you prefer buying parts not intended for your Integra?
Old May 13, 2007 | 09:34 AM
GSR2001's Avatar
An OEM or replica ITR lip would be a far better choice. But I guess like the 205/55/15 tires, you prefer buying parts not intended for your Integra? </TD></TR></TABLE>
RIIIIIIGHT.......
#1 - I'm getting the tires switch to 205/50/15. (phone order mistake)
#2 - I already ordered the Type R lip.
However I don't know where are you getting the part of "buying parts not intended for my Integra".
Is there a set manual to follow for parts that I should put on MY Integra?
or anyboby for that matter.
Spare me the pain, please!!!!!!!!!!!!!
Old May 13, 2007 | 10:27 AM
nsxtasy's Avatar
H-T Order of Merit
Now now, everyone behave, please.
I think the original question was answered...
Baggy Spandex
Jul 26, 2014 06:27 PM
cvclover
Feb 26, 2007 08:37 AM
ejcivicdee
Jun 2, 2006 06:16 PM
98-0688
Aug 24, 2004 03:20 PM
aziz93
Nov 25, 2003 07:45 PM
