boreing over
So I got this CRX and it has the 1.5 fuel injected engine in it and I want to bore it over. Is there a place to find out what the sock bore size and stuff is on it? Or what would be a good bore size to go with? Also what commperssion ratio should I go with?
with stock sleeves you don't want to go crazy with it..40 over the most....But i would do 20 over just incase i have to rebuild later so ill still have some material to take off..
stock is 75mm
stock is 75mm
