k20a2 vs k20z1 wat is pro and cons
z1 cant use kpro unless you get a 02-04 PRB ecu and an adapter harness from hondata
the z1 also doesn't respond as well as the a2 from kpro
z1 tranny uses a "CSS" or was it "VSS" way to get the car speed from the tranny to the speedo so you gotta change out pinouts on the cluster.
z1 i beleive has better pistons/rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloem2 »</TD></TR><TR><TD CLASS="quote">k20a2 vs k20z1 wat is pro and cons</TD></TR></TABLE>
If you are wandering which one to get z1 will bet a a2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awang »</TD></TR><TR><TD CLASS="quote">lmfao! i bet sloem2 has no clue what you're talking about</TD></TR></TABLE>
lol...you are right
lol...you are right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brjhnson »</TD></TR><TR><TD CLASS="quote">
If you are wandering which one to get z1 will bet a a2</TD></TR></TABLE>
Z1 will bet an a2 what?? If you mean beat, it stock for yes it has a BIT more hp, but modded with K-pro and such the difference is very minor. When you think about how much more a Z1 swap would cost (engine and Kpro) the $ difference would = enough mods for an a2 to beat a Z1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz »</TD></TR><TR><TD CLASS="quote">
Z1 will bet an a2 what?? If you mean beat, it stock for yes it has a BIT more hp, but modded with K-pro and such the difference is very minor. When you think about how much more a Z1 swap would cost (engine and Kpro) the $ difference would = enough mods for an a2 to beat a Z1</TD></TR></TABLE>
Yea sorry I meant beat, for some reason I could not spell worth **** yesterday. I was thinking about the gearing being different, and that is why the z1 would win.
yes trust me the gearing in an a2 IMO is perfectly matched with a 215/40/17 tire, any shorter and it would be too short, infact I may go with a taller tire the next time to keep better traction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougEMII »</TD></TR><TR><TD CLASS="quote">u guys do know that they have kpro for the 05+ specific. and i think z1 respond way better to mods. just like most other newer car
Modified by tougEMII at 1:25 PM 5/10/2007</TD></TR></TABLE>
read
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sujak »</TD></TR><TR><TD CLASS="quote">z1 cant use kpro unless you get a 02-04 PRB ecu and an adapter harness from hondata
z1 i beleive has better pistons/rods</TD></TR></TABLE>
read
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougEMII »</TD></TR><TR><TD CLASS="quote">i cant read im illiterate...........</TD></TR></TABLE>
To get the kpro for a 05+ you have to get an 04- ecu
im terribly sorring
im terribly sorring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_Junkie »</TD></TR><TR><TD CLASS="quote">z1 has the rbc intake manifold just like the k20a unlike the type s motor...</TD></TR></TABLE>
wrong..the 06+ Si's have the RBC intake manifold.
the k20a has the PRC intake manifold.
the type s has the PRB intake manifold
the Z1 also have similar, but not exactly the same type R cams.
RACEPAK
37
Apr 7, 2005 04:45 PM
