replacing Synchro's....
Old May 8, 2007 | 09:43 AM
Chuethou_b18c5's Avatar
Default replacing Synchro's....
my 5th gear keeps on popping out once i try to accelerate...would that me indicating that my synchros are bad? thanks*
Old May 8, 2007 | 10:22 AM
sauceja's Avatar
Default Re: replacing Synchro's.... (Chuethou_b18c5)
Would start with your shifter bushings. Cheap and easy and well worth it.
Otherwise I read in the tech/misc section about a bearing that comes out of its hole a little and causes popping out, not sure if that was for 5th gear or 2nd.
You would have to open the case for that but it should be relatively easy.
check tech/misc or some of bense's threads. That is mainly the tranny section any more.
Good luck
Old May 8, 2007 | 11:36 AM
IN VTEC's Avatar
A damaged gear, sleeve, or synchro spring can prevent the sleeve from fully interlocking with the gear.
The 5th gear and synchro set should be replaced. A damaged gear usually means that the synchro sleeve is damaged as well.
Total cost in parts should be around $200.
TomCat39
Transmission & Drivetrain
Oct 11, 2016 02:26 PM
TravisBiggie
Sep 23, 2015 11:42 AM
tmurphnc1985
Feb 2, 2010 05:40 AM
brlabrune
Feb 23, 2009 12:37 PM
HondaRcB
Nov 24, 2006 11:41 AM
