exedy clutch??flywheel?PLS HELLP!!
Old May 8, 2007 | 09:07 AM
mysicivic1991's Avatar
Default exedy clutch??flywheel?PLS HELLP!!
I just bought an Exedy clutch i want to replace my clutch. my car has started to silp and im not sure if i should change my flywheel also is it nessasary???
Old May 8, 2007 | 09:10 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: exedy clutch??flywheel?PLS HELLP!! (mysicivic1991)
You can just get it resurfaced at a machine shop.
Edit: or buy a new one, but you shouldn't just reuse the old one.
Old May 8, 2007 | 09:14 AM
Default Re: exedy clutch??flywheel?PLS HELLP!! (ILcrxsi1)
if i get it resurfaced it will work fine right? the flywheel isn't the one making my car slip is it??
Old May 8, 2007 | 09:15 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysicivic1991 &raquo;</TD></TR><TR><TD CLASS="quote">if i get it resurfaced it will work fine right? the flywheel isn't the one making my car slip is it??</TD></TR></TABLE>No the clutch is what's slipping, on the flywheel. If you get it resurfaced it should be good as new. If your flywheel is too far gone and the machine shop says it can't be resurfaced then you will need to buy a new one.
Old May 8, 2007 | 09:36 AM
thanks alot man
HTLuver
12
Feb 26, 2007 01:20 PM
cdnB18C1
Feb 25, 2006 11:08 AM
Dc_John
Apr 2, 2004 07:57 PM
R-1303
Feb 26, 2003 12:30 PM
Dirty GS-R
Feb 5, 2002 05:08 AM
