detonation help me understand it better
Old May 8, 2007 | 08:26 AM
freshly boosted DOHC ZC's Avatar
Default detonation help me understand it better
how can i tell if my crx is detonating? its a boosted dohc zc tuned with crome pro. at around 4-6 rpms the car backfires a little but and just starts to bog down. would i need to get it retuned after changing the exhaust up a little bit? what does it sound like if a car detonates?
Old May 8, 2007 | 08:43 AM
HOODLOVER's Avatar
Default Re: detonation help me understand it better (freshly boosted DOHC ZC)
someone correct me if im wrong, but IF you here it would prob. sound like a ping
Old May 8, 2007 | 08:49 AM
89efDUSTY's Avatar
Default Re: detonation help me understand it better (HOODLOVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOODLOVER &raquo;</TD></TR><TR><TD CLASS="quote">someone correct me if im wrong, but IF you here it would prob. sound like a ping</TD></TR></TABLE>that is correct...to the OP i believe it occurs when the motor is running too lean and/or the spark is not correct, just take it to a shop and have them dyno tune it...thats a easy for sure way to get no detonating and the a better power curve.
Old May 8, 2007 | 08:56 AM
Default Re: detonation help me understand it better (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">that is correct...to the OP i believe it occurs when the motor is running too lean and/or the spark is not correct, just take it to a shop and have them dyno tune it...thats a easy for sure way to get no detonating and the a better power curve.</TD></TR></TABLE>
it was dyno tuned and an amazing power curve at 5 k. just out of no where today it started to act up but in first gear it acts just fine 2-4th is where it gets choppy. could it be my timing is off a bit? they guys at the shop said it didnt like timing when it was dyno tuned about 3 weeks ago. but i prob should just take it in there...i was thinking it was cause i used ampm's gas the other day when i usually use chevron. and i use nothing other than 92 oct. or maybe its my spark plugs? i should check thos now that im thinking of it.
Old May 8, 2007 | 09:05 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freshly boosted DOHC ZC &raquo;</TD></TR><TR><TD CLASS="quote">
it was dyno tuned and an amazing power curve at 5 k. just out of no where today it started to act up but in first gear it acts just fine 2-4th is where it gets choppy. could it be my timing is off a bit? they guys at the shop said it didnt like timing when it was dyno tuned about 3 weeks ago. but i prob should just take it in there...i was thinking it was cause i used ampm's gas the other day when i usually use chevron. and i use nothing other than 92 oct. or maybe its my spark plugs? i should check thos now that im thinking of it.</TD></TR></TABLE> pinging could also be caused by a lower ocatane i believe...I would run to the store and get some octane booster and see if it diminishs the problem...also what is your AFR?
Old May 8, 2007 | 09:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> pinging could also be caused by a lower ocatane i believe...I would run to the store and get some octane booster and see if it diminishs the problem...also what is your AFR? </TD></TR></TABLE>
its not pinging tho its more of a backfire. here is apic of the final dyno
Old May 8, 2007 | 09:37 AM
89efDUSTY's Avatar
I remember that Dyno...then maybe you are running rich and it is backfire "gas not fully combusting" that would also make it so that car bogs. What is the AFR? I love that curve or a ZC
Old May 8, 2007 | 09:47 AM
i cant remember what the afr was. but it was decent. every thing was tuned just right. but i guess ill take her back to the shop soon for another dyno tune/run and see what is up if it does not clear up in the next few days. and ill see if my brother can remember what the afr was on the car.
Old May 8, 2007 | 09:53 AM
89efDUSTY's Avatar
you don't have a constant monitoring of the AFR&gt;? that is a biggie because it could change espicially depeneding on the FPR...yah if nothing else just have someone hold a cloth rag by the tail pipe and rev the motor...see if it smells like gas, my just be the car is running rich, thereby causing the bogging and backfire gl
Old May 8, 2007 | 10:11 AM
ooops i think i just figured out what it was. think it was casue my # 4 spark plug wire was not all the way connected? just took it out for a real quick spin and it did just fine. and i know i need a afr gauge but funds were low at the time but i should have enough money for one now and the FPR is stock but this summer lots of things are to be changed like a bigger turbo pistons and rods and maybe a sleeved block
Old May 8, 2007 | 10:18 AM
SIred91's Avatar
Rainman
PIXORS PLEASE!!!!!
Old May 8, 2007 | 10:22 AM
Default Re: detonation help me understand it better (SIred91)
gah search for my old post jk
https://honda-tech.com/zerothread?id=1966236
also with a painted valve cover cause before it was chipping
Old May 8, 2007 | 10:46 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freshly boosted DOHC ZC &raquo;</TD></TR><TR><TD CLASS="quote">ooops i think i just figured out what it was. think it was casue my # 4 spark plug wire was not all the way connected? just took it out for a real quick spin and it did just fine. and i know i need a afr gauge but funds were low at the time but i should have enough money for one now and the FPR is stock but this summer lots of things are to be changed like a bigger turbo pistons and rods and maybe a sleeved block</TD></TR></TABLE> nice good find...happy boosting
UTkid
Honda Motorcycles
43
Nov 9, 2007 01:16 PM
imbrzyant
17
Nov 8, 2007 10:40 PM
924doorEG
Jul 8, 2007 04:04 PM
CLman1313
Jul 28, 2006 04:57 PM
RiCE On IcE 2
Jul 1, 2005 01:58 PM
