eg9 cluster speedo problem pls help
Old May 7, 2007 | 11:12 PM
venom363's Avatar
Default eg9 cluster speedo problem pls help
I replaced my cluster because the odometer was sticking but the speedo always worked. I replaced it with the guts of a old guage cluster i found in the at my buddies shop this made the odometer work but the speedo would kick in and out so i thought that the cluster was the problem so i bought a EG9 cluster and installed it, after about 20 mins of driving with it in the speedo went all messed up and reversed starting in the white part at the bottom then the faster i went it would climb backwards from 200kph towards 120kph but the odometer would always work
any one here of this?
pls help me
Old May 7, 2007 | 11:46 PM
BlueIntegraBoy's Avatar
Default Re: eg9 cluster speedo problem pls help (venom363)
Maybe it's your VSS (vehicle speed sensor). Try cleaning the connection.
Old May 8, 2007 | 09:01 AM
venom363's Avatar
Default Re: eg9 cluster speedo problem pls help (BlueIntegraBoy)
i have looked in the manual and it only shows how to take it apart, where is it located?
Old May 8, 2007 | 10:15 AM
Top, rear of the transmission. Search "VSS" to find a pic of it.
Old May 8, 2007 | 11:48 AM
EJ1_Sleeper's Avatar
its very simple, there are 2 parts to it. The gear that is held on my one 12mm bolt, and the sensor and plug which is held to the gear with two 10mm bolts. Try cleaning up the sensor. If that doesnt do it just replace it. Its 5 bucks at the junkyard. I just did it today, and my speedo finally works again (ive been through 2 different ones and my cel just threw a code yesterday. late bloomer i guess i dono.)
mikej94civex
May 25, 2010 05:09 PM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
jerry_ort007
Feb 17, 2009 07:00 AM
NoL1MiT_DC2
Jan 11, 2009 10:51 PM
whitehf
May 10, 2007 08:41 PM
