Dual channel Wideband UEGO Controller
Old May 7, 2007 | 10:24 PM
fsteclipsegst01's Avatar
Default Dual channel Wideband UEGO Controller
dual channel wideband, brand new....
This is the dual channel unit
Im asking 450 OBO or let me know if u have anything to trade.
Specs below*
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM's Wideband UEGO Controller is available in single- and dual-channel models for everything from four-cylinders to V10s, and is the most affordable UEGO sensor controller available. This unit has a very low current draw, and features both 0-5v calibrated output and 0-1v calibrated output to mimic the factory narrow band sensor, eliminating the chance of a factory computer issuing a trouble code. This unit works with virtually any stand-alone engine management system.
Ideal for use with virtually any aftermarket programmable engine management system
Accurate to 0.1 AFR
Available in single- or dual-channel models
BOSCH sensor(s) included
0-5v calibrated output with 0-1v secondary output available to eliminate trouble codes
Reads as rich as 0.55 Lambda
Extruded aluminum enclosure
Laptop or AEM UEGO Display Gauge required for monitoring
Dual Channel UEGO Controller Kit
UEGO Kit; Dual Channel;
Part #: 30-2300
$599.37
Old May 8, 2007 | 07:05 AM
bump
Old May 13, 2007 | 07:02 PM
BUMP
FTP racing
Oct 27, 2007 07:38 AM
AR_motorsports
Honda Civic (2001 - 2005)
Aug 28, 2007 09:15 AM
AllMotorGSR94
Aug 5, 2004 09:39 AM
Sinner
Feb 5, 2004 02:09 PM
