o2 sensor and hondata
Old May 7, 2007 | 07:59 PM
JcAst99's Avatar
Default o2 sensor and hondata
ok i got a 99gsr that i switched over to obd1 with hondata, when i got engine rebuilt... I am pretty sure im in the need of o2 sensors b/c my gas mileage has been bad since b4 the rebuild. I know that only one o2 sensor is functional with obd1, im pretty sure its the rear. So if i want o2 sensors do i need to get both changed, or only one? Thanks for any replies
Old May 8, 2007 | 05:30 AM
diversegsr's Avatar
Default Re: o2 sensor and hondata (JcAst99)
I would change both to be on the safe side ......you can either get oem which is $$$$ or get bousch or ngk which is more reasonable priced
Old May 8, 2007 | 09:39 AM
Spunkster's Avatar
OBD1 uses only the Primary sensor
Old May 8, 2007 | 11:23 AM
diversegsr's Avatar
Default Re: o2 sensor and hondata (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 uses only the Primary sensor</TD></TR></TABLE>
good call....didnt think about that...
Old May 9, 2007 | 06:59 PM
JcAst99's Avatar
Default Re: o2 sensor and hondata (diversegsr)
soo i would only need the sensor closer to engine rather than the one closer to the muffler?
Old May 11, 2007 | 08:19 AM
Spunkster's Avatar
Primary is the one in front
Old May 11, 2007 | 11:22 AM
allanonjj's Avatar
buy yourself a wideband (plx is the easiest Ive found to deal with when running Hondookie) and check your a/f. If your gonna do any serious tuning (which you should on any built motor), the wideband will be a god send. The Primary wideband is the one directly under your intake mani
bopbop93030
Dec 19, 2008 09:53 PM
slowestcarever
May 3, 2004 08:28 PM
LS stretch
Mar 17, 2004 01:41 PM
integranator
Jul 16, 2003 09:46 PM
irev210
May 1, 2003 09:24 AM
