help with oil pan
Old May 7, 2007 | 07:16 PM
97_dc2's Avatar
Default help with oil pan
i was wondering if there is any differences between the oil pans beacause i am going to change it. my motor is a 94 gsr. would be great if i could get help
Old May 7, 2007 | 07:39 PM
numbnuts22715's Avatar
different oil pans according to what?
you need to get a vtec oil pan.
I would recommend just getting a gsr one so you definitely wont have any trouble.
an LS, I believe, is deeper than agsr, but I could be wrong and have it backwards.
Old May 7, 2007 | 07:49 PM
GSRNetics's Avatar
Default Re: (numbnuts22715)
You need the VTEC oil pan. LS oil pan will not work on a GS-R block.
Old May 8, 2007 | 07:41 AM
slammed95dc2's Avatar
Default Re: help with oil pan (97_dc2)
ls/b20/b16 oil pans are the same, itr/gsr are the same so you cannot interchange them without swapping the oil pickup at the same time.
Old May 8, 2007 | 12:06 PM
97_dc2's Avatar
Default Re: help with oil pan (slammed95dc2)
ok thanks for the help.
Old May 8, 2007 | 01:01 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">different oil pans according to what?
an LS, I believe, is deeper than agsr, but I could be wrong and have it backwards.</TD></TR></TABLE>
Backwards is correct, gsr has a deeper oil pan cause of the girdle.
So the Ls/girdleless blocks can't be used on blocks such as the gsr.
Old May 8, 2007 | 06:54 PM
97_dc2's Avatar
Default Re: (CleanLikeJdm)
thanks for the help. i think this info will help me out alot
240_Sergio
Mar 12, 2010 08:26 AM
wesleywhite989
Aug 21, 2008 07:16 PM
EJ8chu
Sep 14, 2006 09:40 PM
SlammedBlackGSR
Sep 13, 2006 09:36 AM
