fog lights installed what happened?
Old May 7, 2007 | 06:22 PM
Civic Racer X 7's Avatar
Default fog lights installed what happened?
ok so I took my jdm fogs to the local shop
I picked up the car and everythign was lookin good
the button was instakked next to the dimmer
and the fogs worked when the headlights and the switch were on
now heres where it gets weird
I have no CLUSTER lights?
whats the deal
I have tail lights and the fuse is good
they worked when I dropped it off
any idea what got took loose or what happened?
I removed the NEW fog light switch and dimmer switch just to see if one of the plugs wasnt plugged in and they are fine
prolly gonna go back to the shop tomorrow
Old May 7, 2007 | 06:26 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: fog lights installed what happened? (Civic Racer X 7)
They obviously messed up some wiring. Your cluster lights are supposed to come on with your parking lights. Some wires might be crossed or something got messed up during intall.
It's the shops fault, let them fix it.
Old May 7, 2007 | 06:33 PM
Cookie's Avatar
Default Re: fog lights installed what happened? (ek forever guy)
Yeah, I would stand around a watch them, unless you have a good relationship with them. Sometimes when a shop gets a car back they give back to the tech that did the work,,, if he has an attitude,, whoa.
Aside from that. it's probably a ground wire or something.
Old May 7, 2007 | 07:38 PM
BlueIntegraBoy's Avatar
Check the wires going into the dimmer switch plug...
Old May 7, 2007 | 08:12 PM
truevietluv636's Avatar
you should go back to the shop and get your money back.
Old May 7, 2007 | 08:24 PM
Ek Forever y0!
Default Re: fog lights installed what happened? (truevietluv636)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 &raquo;</TD></TR><TR><TD CLASS="quote">you should go back to the shop and get your money back. </TD></TR></TABLE>
Or just tell them to fix it.
People make mistakes.
Old May 8, 2007 | 01:53 PM
well this sux the shop checked everythign and said its good but still no lights
I removed the panel and foudn that if u WIGGLE the wires that hook to the dimmer switch the lights will come on
they must have yanked on the wires or something or maybe they are grounding somehow
its weird if I pull on them the lights work and if I let the slack up they go off
guess I gotta find an auto electrician now
Old May 8, 2007 | 02:03 PM
Ek Forever y0!
Default Re: (Civic Racer X 7)
^ still, have the shop pay for it. They worked when you left the car with them. It should be their reponsibility to keep your car in working order.
Old May 8, 2007 | 03:28 PM
Agent_EM1's Avatar
Default Re: (ek forever guy)
Fuggin shops... They've found new tricks other than the pot hole infront of the wheel shop trick
Jamie Martin
Jan 14, 2013 07:17 AM
Civic_kid_666
Jan 8, 2008 01:40 PM
aojtin
Nov 25, 2007 06:36 PM
HondaKPX
Jul 25, 2005 10:44 PM
ImprtTuner88
Nov 19, 2002 04:09 AM
