b18 swap into ej1 searched....
it will be awhile but i want to put a b18 into my ej1 when the d16 goes to **** on me
i know i need ecu, tranny, b series linkage, mount kit, of course the motor, but do i need different axles and what else a different wiring harness maybe? i'll check this back in the morning i'm going to sleep... got college in the morning and work after that i need my rest TIA guys
oh and by the way i searched and came up with a how to switch wiring harness and a ton of fs and wtb threads and one about switching to an eg which told me what i already know... no help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">it will be awhile but i want to put a b18 into my ej1 when the d16 goes to **** on me
oh and by the way i searched and came up with a how to switch wiring harness and a ton of fs and wtb threads and one about switching to an eg which told me what i already know... no help</TD></TR></TABLE>
Well, you didn't search enough. There must be a gazillion articles about swaps in the 5th gen civic.
1) B18 what? B18C1? B18A, B18B?? You need to specify.
2) You need: Motor, Tranny, Axles, Harness, ECU, Mounts, Linkage and some coolant hoses. ALL for the engine you want to install - (Depends on which B18 you get A,B,C)
GL with the swap.
Check the FAQ and here's what I found in 2 minutes.
https://honda-tech.com/zerothread?id=856396
GL with the swap.
