Vtec solenoid bolts.
Old May 7, 2007 | 03:36 PM
Boostedb20EH2's Avatar
Default Vtec solenoid bolts.
When i bought my b16 head im about to put on my car the vtec solenoid came seperate. Does anyone know the exact measurement of the bolt i need. There is 3 of them.
Old May 7, 2007 | 04:27 PM
Default Re: Vtec solenoid bolts. (Boostedb20EH2)
All of the questions that are asked 1000000 times a day get 50 replies but ones that are rarely asked get 0
Old May 7, 2007 | 05:05 PM
dpaton's Avatar
Walk yourself to the parts counter at your local Honda dealer and ask for the bolts for the solenoid off of a 99si. Problem solved. Or use one of the dozens of online sites to look up the part number, and maybe the specs of the bolts. It's not rocket science.
Old May 7, 2007 | 05:30 PM
Default Re: (dpaton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton &raquo;</TD></TR><TR><TD CLASS="quote">Walk yourself to the parts counter at your local Honda dealer and ask for the bolts for the solenoid off of a 99si. Problem solved. Or use one of the dozens of online sites to look up the part number, and maybe the specs of the bolts. It's not rocket science.</TD></TR></TABLE>
Already done that,they told me they dont stock them and would have to order them and basically they dont want to do that so they told me to find them at a hardware store (which is easier anyways). I would like to pick them up at a local hardware store..
Old May 7, 2007 | 05:31 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Boostedb20EH2)
I bet a tech could look up the bolt specs for you.
And I bet a hardware shop employee could find you a bolt in those specs.
Problem solved.
Old May 7, 2007 | 05:34 PM
Default Re: (ek forever guy)
Hey guys, look..
Im not trying to cause a problem. Im just saying that i know there are people on here that know the exact size of the 3 bolts and im just asking for them to reply.
Old May 7, 2007 | 05:41 PM
Ek Forever y0!
Is it the mounting bolts or the pressure test port?
I'm looking it up for you.
Old May 7, 2007 | 05:47 PM
It lists 6x30.but i went to home depot and 1 they only stock 6x32 and 2. it was really small and in no way did it look like it would fit.
Old May 7, 2007 | 05:50 PM
Ek Forever y0!
Home despot has the shittiest selection in bolts I've ever seen.
Try a Fastenall or an auto parts store.
The solenoid is the same for all b-series, so you could always head to a junkyard. I bet they'd charge you pennies if anything for 3 bolts.
Old May 7, 2007 | 05:51 PM
94Hatchd15b7's Avatar
MMMM I believe that the three bolts on the V-TEC solenoid are 10mm heads and 6x30 threads. Which equal 6m threads.
Old May 7, 2007 | 05:55 PM
Ek Forever y0!
Default Re: Vtec solenoid bolts. (94Hatchd15b7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Hatchd15b7 &raquo;</TD></TR><TR><TD CLASS="quote">MMMM I believe that the three bolts on the V-TEC solenoid are 10mm heads and 6x30 threads. Which equal 6m threads.</TD></TR></TABLE>
OP already posted the size. Thanks Captain 4 "minutes-too-late."
Honestly, I'd head to a junkyard if their is one conveniently located near you.
Old May 7, 2007 | 05:57 PM
vtecftw's Avatar
I belive they may be pretty specific bolts, you might want to check out honda for the screws, better off overpaying for bolts at honda that you know will fit than stripping something out
If they dont stock them, they should take 1 or two days to come in
just relax and wait 2 days
Old May 7, 2007 | 05:59 PM
Default Re: Vtec solenoid bolts. (ek forever guy)
Hey, thats Captain 4 "minutes-to- late"
Old May 7, 2007 | 06:00 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Hatchd15b7 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, thats Captain 4 "minutes-to- late" </TD></TR></TABLE>
I sit corrected
EDIT: Fixed it for ya.
Old May 7, 2007 | 06:02 PM
Alright thanks guys. It kind of pissed me off honda sent me off on my way with nothing but oh well. I'll stick it to them
Old May 8, 2007 | 10:15 AM
kb0821's Avatar
If you are talking about the 3 bolts on the top, then here's the specs:
they are 6mmx18mm metric flange bolt. You can get them at any metric hardware store for about a buck a peice or you can try calling Honda.
Old Aug 10, 2024 | 11:12 AM
amedeus's Avatar
my ivtec screw has broken, i found it at this site, but its at holand, you may try to contact them contact form, they will need engine to identify your part.
https://www.a4h-tech.com/
Old Aug 10, 2024 | 09:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You are about seventeen years too late to help there rookie... glad that you got yours fixed though.
Arthas
Honda S2000
Jan 26, 2015 03:21 AM
dc101
Jul 27, 2010 07:38 PM
RaceCity_USA
Jun 1, 2006 01:07 AM
nissanjon
Oct 12, 2004 02:40 PM
ltho1998
Jul 25, 2003 12:05 AM
