JDM hood installation issue
Old May 7, 2007 | 03:18 PM
ef9robert's Avatar
Default JDM hood installation issue
Guys and gals,
I am trying my best to get this damn hood installed. I have failed miserably. If any has installed one and is in the 626 hit me up please. I need a friendly hand to get this damn hood on straight.
Thanks.
Old May 7, 2007 | 03:30 PM
Janos Lin's Avatar
Default Re: JDM hood installation issue (ef9robert)
If ur talking about a SIR hood, you need a SIR bumper and I think fenders for it all to work. Some companies do sell SIR style hoods intended to work with USDM front ends. If you have the SIR bumper and fenders, ignore me then :D
Janos
Old May 7, 2007 | 05:54 PM
Bob_760's Avatar
Default Re: JDM hood installation issue (Janos Lin)
Aside from the hole for the sidemarker fenders are all the same... you need jdm headlights, front bumper, and the right t-bar though. Assuming you have the components for a JDM front, you probably have the wrong t-bar or you're using the usdm bar. It is possible to get the usdm t-bar to work, kinda, but the acctual SiR t-bar dosen't work, you need the t-bar from an "SiR front" non SiR.
Old May 8, 2007 | 07:39 AM
ef9robert's Avatar
Yah i have the whole front clip, fenders, hood, bumper and tbar. still cant get the damn thing to close.
Any other suggestions?
Old May 8, 2007 | 08:10 AM
EF_LSVtec's Avatar
You have to put some washers to move the latch forward. I used plastic ones from my local hardware store
Old May 8, 2007 | 08:47 AM
ef9robert's Avatar
hmm i will try that, I think i figured it out though. You need to take the hood latch off the hood and elongate the holes on the hatch and not the hood!!! I will report if i am able to get this completed.
Old May 8, 2007 | 08:52 AM
EF_LSVtec's Avatar
Default Re: (ef9robert)
just move the "T"bar on the car forward and keep the latch on your hood in place.
Old May 8, 2007 | 09:49 AM
ef9robert's Avatar
so the washers are under the t-bar and the mounting holes? Could you give me a shot of the washers only?
Old May 8, 2007 | 10:56 AM
Bob_760's Avatar
That'll work but FYI if you get the right T-Bar it'll bolt up and latch like stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">just move the "T"bar on the car forward and keep the latch on your hood in place. </TD></TR></TABLE>
Also you should mention thats an SiR T-Bar (he still hasn't said which one he's using)
Modified by Bob_760 at 3:08 PM 5/8/2007
Old May 8, 2007 | 11:35 AM
ef9robert's Avatar
i believe the clip was of a EF3 since it still has the JDM VIN tag on it (blue)
Old May 9, 2007 | 11:40 PM
Rex_89's Avatar
Im going through the same thing right now. Anyone know where I can find the right t-bar? I tried the washer thing under my stock t-bar and now my hood doesnt sit flush
Old May 10, 2007 | 02:23 PM
Rex_89's Avatar
Default Re: (Rex_89)
bump for help....
Old May 10, 2007 | 02:25 PM
doublethink's Avatar
you can mod it, its not hard.
look at this image and read this thread:
https://honda-tech.com/zero...28699
Old May 10, 2007 | 02:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex_89 &raquo;</TD></TR><TR><TD CLASS="quote">bump for help....</TD></TR></TABLE>
also follow whats written in this how to:
http://faq.ef-honda.com/index....ng=en
Old May 11, 2007 | 08:11 AM
EF_LSVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9robert &raquo;</TD></TR><TR><TD CLASS="quote">so the washers are under the t-bar and the mounting holes? Could you give me a shot of the washers only?</TD></TR></TABLE>
Left of the picture, above the headlight...notice 2 white plastic washers on the Tbar mounting screws.
Old May 11, 2007 | 09:58 AM
Zaakro's Avatar
Default Re: (EF_LSVtec)
https://honda-tech.com/zerothread?id=1700836
for the correct T-bar
Old May 11, 2007 | 11:57 AM
Jerms's Avatar
expletive washers that looks like ****
thumbs up for the right t bar or u can redill the holes and mount it on
Old May 11, 2007 | 01:16 PM
Default Re: (Jerms)
If you have the right T bar all you gotta do loosen all size 10 screws that holds it in place and pull it pull it as far as it goes and the latch has to be moved as forward as possible also......bolt both of them down.....then you play with the part that goes in the hole....i had to bend it back just a little ....but my hood closes flush.......
Old May 11, 2007 | 01:19 PM
Default Re: ("Jap*****")
Hey i remember i volunteered to help you throw your front end on a while back.....I stay in the 323 area.
Old May 11, 2007 | 03:23 PM
EF_LSVtec's Avatar
Default Re: (Jerms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerms &raquo;</TD></TR><TR><TD CLASS="quote">expletive washers that looks like ****
thumbs up for the right t bar or u can redill the holes and mount it on</TD></TR></TABLE>
Those were the right T bar that I used (came with the jdm clip)...and those expletive washers that looked like ****?? Did the job! $2 fix without redrilling holes.
Old May 11, 2007 | 07:24 PM
soodominican's Avatar
wuts a t bar?
Old May 12, 2007 | 02:06 PM
Zaakro's Avatar
Default Re: JDM hood installation issue (soodominican)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soodominican &raquo;</TD></TR><TR><TD CLASS="quote">wuts a t bar?
there is no hope for you
Old May 12, 2007 | 09:20 PM
Bob_760's Avatar
Those were the right T bar that I used (came with the jdm clip)...and those expletive washers that looked like ****?? Did the job! $2 fix without redrilling holes.</TD></TR></TABLE>
No offense but to keep the facts in this thread straight thats not the right T-bar... If you had the right one you wouldn't need washers and it wouldnt have the SiR's air snorkel hole. Apparently with those huge washers in there its far enough farward to work though, so it is another option.
Old May 12, 2007 | 09:41 PM
EF_LSVtec's Avatar
Default Re: (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">
No offense but to keep the facts in this thread straight thats not the right T-bar... If you had the right one you wouldn't need washers and it wouldnt have the SiR's air snorkel hole. Apparently with those huge washers in there its far enough farward to work though, so it is another option.</TD></TR></TABLE>
How can that not be the right T bar when like you said, it has the SiR air snorkel hole? Why do I even bother sometimes... So what you're saying is that the JDM EF9 front end is a direct swap to a USDM car, because the right T bar wouldn't require the use of washers to move the latch forward??
btw, no offense taken...
Modified by EF_LSVtec at 11:34 PM 5/12/2007
Old May 13, 2007 | 07:28 PM
Bob_760's Avatar
Modified by EF_LSVtec at 11:34 PM 5/12/2007</TD></TR></TABLE>
Sorry, I was pretty vague. The SiR chassis is longer than the regular chassis which is why you needed washers to place the t-bar in the same place it'd be on an SiR relative to the hood. The t-bar needed is from an Si with the SiR front end, they had them they way from the factory in Japan. With said t-bar it bolts in just like the stock t-bar (no washers, no notching holes, no nothing) and the hood shuts and latches perfectly.
It's all in there also... vv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1700836
for the correct T-bar</TD></TR></TABLE>
Theres probably nothing wrong with your setup since the t-bar is pretty much where it should be but theres an easier/cleaner way.
