spoon ecu questions?
Old May 7, 2007 | 12:47 PM
90crxdxb16's Avatar
Default spoon ecu questions?
i have an authenic spoon sports obd0 ecu for my jdm b16(as far as im aware). I just recently put my cyclinder head and all back in and got it running again. I went to the ecu after running it 3 or 4 times to check to see if im getting codes. what does it mean if the ecu blink once real fast and nothing else? I have not used the ecu before. thanks alot guys
Old May 7, 2007 | 12:53 PM
90crxdxb16's Avatar
Default Re: spoon ecu questions? (90crxdxb16)
also i was wondering since its all back toegether running good is there any one thing i should go back to and retorque or double check on? this was my first time taking this much of an engine apart. so maybe im paranoid.. but id rather be safe then sorry
Old May 7, 2007 | 01:00 PM
wiZCo's Avatar
Stouts 'n' Scotch
Should be code 1: oxygen sensor. You may just want to try to reset the ECU first and see if it goes away.
Old May 7, 2007 | 01:14 PM
90crxdxb16's Avatar
Default Re: (wiZCo)
ok, i will but its werid because, i have checked codes before it blink once real quick when you turn the key to start position, then does nothing else im assuming its probly not a big deal the car runs good.
Old May 7, 2007 | 01:17 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (90crxdxb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 &raquo;</TD></TR><TR><TD CLASS="quote">ok, i will but its werid because, i have checked codes before it blink once real quick when you turn the key to start position, then does nothing else im assuming its probly not a big deal the car runs good.</TD></TR></TABLE>
Oh, that's nothing.
Old May 7, 2007 | 01:19 PM
90crxdxb16's Avatar
Default Re: (wiZCo)
ok cool i just wnat to be familiar with my stuff so i thuaghted id ask to make sure something wasn't wrong. thanks
Old May 7, 2007 | 01:27 PM
90crxdxb16's Avatar
i got one more question.. since i went high compression on the valvetrain do you think it is necessary for an aftermarket stronger timing belt?
A51_RPS13
Nov 12, 2007 07:26 PM
an2ny888
Mar 3, 2005 01:36 AM
kim_2_da_chee
May 30, 2003 06:18 PM
ITR292
Mar 4, 2003 10:32 AM
iNteKra
Oct 25, 2001 07:18 PM
