stock seat belt on recaro???
Old May 7, 2007 | 12:45 PM
forenzixEJ8's Avatar
Default stock seat belt on recaro???
need some help...i jus got a set of recaros for my ek coupe but they dont have anything for a seat belt to clip into, i do have a set of some stock ex seats i can take them off of but does anyone know where i can bolt them to on the recaros????
Old May 7, 2007 | 01:46 PM
B16smku's Avatar
Default Re: stock seat belt on recaro??? (forenzixEJ8)
I have a set of recaros in my EK hatch, and I went and checked them. It seems they are directly bolted on. Not quite sure why yours isnt. Which kind of recaros do you got?
Old May 7, 2007 | 02:37 PM
B16b-EJ8's Avatar
Default Re: stock seat belt on recaro??? (B16smku)
Yes the type of recaro youhave would help a lot.
Old May 7, 2007 | 03:44 PM
Default Re: stock seat belt on recaro??? (B16b-EJ8)
there srd's like a universal style recaro, there is a bolt it looks like i could undo and bolt up the stock buckle to it, i jus put them in and havent tried jus tryin to get a idea before i pull them out to do it, let me kno what u guys think
Old May 7, 2007 | 03:47 PM
B16b-EJ8's Avatar
I would assume that that bolt will be where the stock buckle will bolt to...take a look a the stock seat buckle location and see if it is similar in design to the recaro...should be the one though
Old May 7, 2007 | 04:07 PM
97Ej6mike's Avatar
I ran into the same problem with my aftermarket seats, you need to do a DIY with your stock seatbelt clip. Your going to need a Bolt and nut, fairly thick, not too long tho, and some washers.
There should be a panel on the lower sides that is removable, exposing a frame that supports the recliner. With mine, there was already a bolt hole to which i fastend the extra bolt and nut to, that holds my clip in place, Much tighter than my stock one did.
square_1
Dec 11, 2006 02:18 AM
black00civicsi
Apr 8, 2005 09:40 PM
zm_dawg
Oct 15, 2004 12:34 AM
Spoold_R
May 14, 2004 06:22 AM
DeDonDeRosa
Mar 15, 2004 11:22 AM
