2006 Air Filter
Old May 7, 2007 | 12:33 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default 2006 Air Filter
The owner's manual does not mention anything about changing the air filter. I looked in the index too, with no luck.
Am I not seeing it in the owner's manual?
I just want to ask before I start so I don't unscrew more than I need to.
TIA
Old May 7, 2007 | 01:10 PM
JimBlake's Avatar
Default Re: 2006 Air Filter (GoLowDrew)
The owner's manual probably just lists a replacement interval in miles / months. Maybe doesn't have actual instructions for doing it.
V-6? 4-cyl? They're probably not the same as each other...
Old May 7, 2007 | 02:25 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: 2006 Air Filter (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The owner's manual probably just lists a replacement interval in miles / months. Maybe doesn't have actual instructions for doing it.
Correct.
It's a 4.
I changed the air filter on my 05 Ford, like the Honda, there seems to be the air flow sensor connecting to it. It's not hard, just that I removed more screws than I should on my Ford, and made it a longer process. No big deal, just more chances to drop a screw, etc. And then can't find it. That's why I'm looking for step by step instructions in the owner's manual.
Old May 7, 2007 | 07:37 PM
JimBlake's Avatar
Here's the air filter housing. That air flow sensor is #15, otherwise it's the same as my '03. Be careful you don't mess up the business end of that sensor.
The rubber air intake tube is short & stiff, so I find it easier to loosen both ends. Then there's the steel tubing for the crankcase vent...
The screws that close the airfilter housing (#18) are captive, so they don't easily fall out. But for some strange reason, Honda made that thing so it's a PITA to wrestle the lid (#5) out alongside the fender.
Old May 7, 2007 | 09:10 PM
epeen's Avatar
yuup thats for the filter. but there is also a resonator. cant take it out witout removing front bumper qq... if u ever wanted a CAI.
humphrey1989
Sep 5, 2015 11:52 AM
smetzger
Honda Fit
May 14, 2011 07:16 PM
derekcentrico
Dec 12, 2009 11:38 AM
hondateg08
Honda Civic (2006 - 2015)
24
Apr 15, 2009 10:09 AM
NealPT
Dec 29, 2004 08:31 AM
