Cruise question
Old May 7, 2007 | 12:12 PM
Burnt Toast's Avatar
Default Cruise question
I have a 00 civic si that had a d16y8 block topped with a d16y8 head unstalled in it before I got it. The cruise control parts seem to be inplace yet, except for the vacuum lines from the actuator to the intake manifold. The y5 intake manifold does not have a nipple for the cruise control anywhere on it. I would like to keep the y5 intake on it, it is presently getting over 38 mpg.
My question is this:
Can I drill, tap and install a vacuum nipple for the cruise control? Does it need to be located in a certain area on the intake body (plenum, I think) to work properly?
Can I tap into a different vacuum line?
Old May 7, 2007 | 01:20 PM
one_boosted_si's Avatar
Default Re: Cruise question (civic stud)
Vacuum is vacuum, install a "t" fitting in-line and be done with it. An easy vacuum source is usually your FPR as it's normally on the top side of your fuel rail/IM.
EJ8_Man
Jan 18, 2011 08:55 PM
CAM0FLAG3
Welding / Fabrication
Jun 27, 2008 06:30 PM
b18cEK
20
Jun 21, 2005 10:29 AM
93sleeper
Mar 22, 2005 01:50 PM
retriever99
May 21, 2004 11:17 AM
