ZeX Nos kit. ~!~?!?!?!?!??!?!?!!!!!!!!!!
Okay i have a 75 shot zex kit in my car i am about to build up my motor from the bottom and then some head work. I was wondering could i shoot about 105,115,or 120 shots on my Zex kit or does 75 cut off the amount????
[Modified by EGkTiOn_CiViC, 4:29 AM 5/31/2002]
i think 75 is the highest you can go with the zex kit b/c its a dry kit. anything more will get to lean and cause your motor to blow. if you want to go higher then a 75 shot, try a wet kit. nos brand and also n/x make them. hope this helps
just so you know, it is a zex NITROUS kit. or you could have a NOS nitrous kit. But not a zex NOS kit, unless there was a merger and I haven't heard about it.
The solenoid in the ZEX kit will flow 200+ hp.
But over 75-85 shot on a dry kit will = BOOM!
Next trick = convert ZEX kit to direct port setup.
Stay at 75 shot, or get a direct port wet system.
Dude.. if ZEX and NOS(brand) actually teamed up, that would be one bad *** nitrous kit.. ZEX is known to be the safest kit out there while NOS(brand) is known to be reliable and give the most hp gains.. it would have the best of both worlds..does anyone have any info on this team or is it just a rumor?
Double 06
Jun 3, 2002 08:31 PM
