anyone know where i can buy this
Old May 7, 2007 | 10:50 AM
dcskater6767's Avatar
Default anyone know where i can buy this
hey im looking for a intake manifold for my 92 honda accord it has a f22a1 i dont want the stock one i wanna buy a Performance one but i cant seem to find one does anyone know where i can buy one or if i have to buy one for a h22 engine if that will fit? but if someone knows it will be much help thanks.
Old May 7, 2007 | 10:55 AM
FDAccord's Avatar
your best bet is probably an F22A6 intake manifold from the SE accords.
Old May 8, 2007 | 04:42 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (FDAccord)
The F22A6 and H23A1 intake manifolds are almost the same.
So with that in mind, you can look for any intake manifold for the 90-93 Accords or for the 92-96 Prelude Si non-VTEC.
The H22 intake manifold won't bolt up IIRC.
Old May 8, 2007 | 09:44 AM
Default Re: (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">The F22A6 and H23A1 intake manifolds are almost the same.
The H22 intake manifold won't bolt up IIRC.</TD></TR></TABLE>
so ur saying that i can take one from a 92-96 prelude si and that will up my hp by a good bit for my car?
Old May 8, 2007 | 09:53 AM
H-T Order of Merit
Default Re: (dcskater6767)
I wouldn't say a good bit but it's better than the one you have.
The F22A6 and H23A1 intake manifolds have dual runners. The idea is that the shorter set stays shut during low rpm driving to give better torque. Then the secondary valves open to allow air into the shorter second runners during higher rpm driving to give better hp.
take a look at this write-up for some more info on this.
http://www.cb7tuner.com/vbb/showthread.php?t=16242
Superdragr45
Oct 18, 2019 04:35 AM
Mangotreemechanic
May 10, 2006 07:27 AM
Power Rev Racing
Nov 22, 2005 06:50 AM
GOTNOS
Oct 6, 2004 04:42 PM
