Code 4 fault in the transmission control unit......WTH is that?
Old May 7, 2007 | 10:12 AM
PyroProblem's Avatar
Default Code 4 fault in the transmission control unit......WTH is that?
I have my D4 light blinking on my 94 accord. I jumped the connector and the D4 light blinks 4 times quickly.
I assume this is code 4, but I cannot fing any info on this fault.
My speedo does not work either, but there is a fault in the ECU for this, code 17...
I need to know if this is something i ca fix myself or if the tranny is about to die.
If its about to die, I need to dump this thing to recoup my $$$...
Yes, I searched and No im not talking about code 4 for the ecu(CYP sensor)...
Thanks HT
Old May 7, 2007 | 10:56 AM
Default Re: Code 4 fault in the transmission control unit......WTH is that? (PyroProblem)
bump for these wonderfully reliable automatic transmissions!
Old May 7, 2007 | 05:42 PM
Anyone know if fault code 17 in the ECU(speed sensor) will trigger fault 4 in the TCM( unknown fault).
This will be the deciding factor of whether I keep this POS or sell it...
Auto trannies
Old May 7, 2007 | 06:43 PM
hondadude's Avatar
I think it is the other way around. LOL
The code 4 from the TCU sent the code 17 to the ECU.
Replace the speed sensor and life should be all good again.
Here's a link for you;
http://img252.imageshack.us/my...j.jpg
Old May 8, 2007 | 06:20 PM
Thank you Honda dude!
I finally got an answer today as well from a friend of a friend that works at honda.
Thank you for confirming.
I guess this is going to be my beater from now on
hatch96y7
Nov 19, 2007 10:58 AM
drewboy
May 14, 2005 10:03 PM
h22acivichybrid
Jun 3, 2004 03:24 PM
4gnhatch
Jun 2, 2003 12:35 PM
IamVtec
12
Nov 2, 2002 04:50 AM
