Factory Freak?
It's difficult to compare numbers from a compression tester, or to use those numbers as an indicator of the actual compression ratio. The motor appears to be quite healthy from a compression standpoint, but I wouldn't assume that it somehow has greater static compression than any other stock B18C ITR motor.
builtprelude
Jan 22, 2004 10:49 PM
siis2fast
Jun 16, 2003 11:09 AM
