removing antena and filling hole?
Old May 7, 2007 | 05:23 AM
a2dadamm's Avatar
Default removing antena and filling hole?
hey guys my antenna doesent work so i was thinking to take it out and just cover the hole with some bondo and then paint over it but im not sure hole to fill the hole i assume id have to put something there to block it cant just smudge bondo over it it will fall linto the hole is ther anything made for this or somthing i could use.?
i saw at the auto part store like a mesh that is sticky on one side if i cut a piece and then stick it on thi inside then do bondo to fill in the rest would that work?
Thanks
Old May 7, 2007 | 05:52 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: removing antena and filling hole? (a2dadamm)
The best thing to do would be weld up the hole. If that's not an option, you may look into a metal to metal adhesive. There's a little bit of information on that in this thread... https://honda-tech.com/zerothread/1975215
Old May 7, 2007 | 10:20 PM
Danger's Avatar
Default Re: removing antena and filling hole? (-NA-aLL-thE-wAy-)
do you have access to a welder ? take out the antenna and try and cut a piece of metal about the same size of the hole , weld it up . last resort take it to a muffler shop and ask them to weld it on and then grind it down . you should be able to handle the bodywork from there .
Old May 9, 2007 | 04:07 AM
a2dadamm's Avatar
Default Re: removing antena and filling hole? (Danger)
i do have acsess to one and im thinking i might as well try it myself right. gotta figure out somehow if you can do things in life.
Old May 9, 2007 | 09:44 AM
Auby's Avatar
Bondo/Fiberglass!!!!! Works like a charm!
Old May 9, 2007 | 11:20 AM
EFSS153
Default Re: (Auby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auby &raquo;</TD></TR><TR><TD CLASS="quote">Bondo/Fiberglass!!!!! Works like a charm! </TD></TR></TABLE>
After the hole is welded up, of course.
Old May 9, 2007 | 01:59 PM
Auby's Avatar
why do you have to weld it? you dont just put some bondo and fiberglass and you will be good.
Old May 9, 2007 | 09:43 PM
quicknadc2's Avatar
i did all my body holes with fiberglass on both sides and then bondo to smooth it out , its worked out good nothing wrong with it, but i thinks its better to have everything welded bondo on cars is gay.hehe.
Old May 10, 2007 | 01:47 PM
Auby's Avatar
but its a lot cheaper and it looks just the same when it is painted!
Old May 10, 2007 | 02:01 PM
WihaSi's Avatar
Default Re: (Auby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auby &raquo;</TD></TR><TR><TD CLASS="quote">why do you have to weld it? you dont just put some bondo and fiberglass and you will be good.</TD></TR></TABLE>
Well because if you just slapped a **** load of putty on it you could poke your damn finger through it...the correct method would be to weld it, grind it, then use your plastic filler. Don't be a damn butcher, do it right.
Old May 10, 2007 | 06:40 PM
EFSS153
Default Re: (WihaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote">
Well because if you just slapped a **** load of putty on it you could poke your damn finger through it...the correct method would be to weld it, grind it, then use your plastic filler. Don't be a damn butcher, do it right.</TD></TR></TABLE>
Exactly.
Old May 10, 2007 | 06:57 PM
TurboCoop's Avatar
you can do it without welding but that it stupid, just grind th epaint off around the hole, cut a little peice of around 20 guage sheet metal, stick it up behing it from the inside, tack it a few times being careful not to get it too hot and warp anything, then fill it in with bondo. Its easy as hell. The pain in the *** will be having to paint the whole panel where it is
Old May 10, 2007 | 07:04 PM
chitownrida's Avatar
dont do straight putty like everyone said before its too fragile.. i had a buddy weld in a small sheetmetal patch then use some mud to clean it up
Old May 11, 2007 | 06:06 AM
Auby's Avatar
Its not just stright putty. You cover it with the fiberglass and then use the bondo. They make body kits of of fiberglass. Fragile, yes but not the much i mean its going over a small hole.
Old May 12, 2007 | 07:36 PM
soisauce's Avatar
Default Re: (Auby)
I wish I would have gotten the squirtters on my hood welded Now there cracking because of the Texas sun warping and expanding the metal and bondo.Now I gotta spend more money to fix it, Get it welded, do it once do it right, I had to learn the hard way.
Old May 13, 2007 | 10:13 PM
dem0nk1d's Avatar
before you go F$ucking your windshield up with a welder from the hot sparks. Lay a wet towel over your windshield, and any other glass. Or you'll be sorry.
dc4teg95
Paint and Body
Dec 27, 2010 05:34 AM
avaldez
Welding / Fabrication
12
Jun 11, 2009 08:33 AM
CBURKE
Jun 12, 2006 01:31 PM
contender
Feb 4, 2005 09:00 AM
kim_2_da_chee
13
Jan 8, 2003 12:39 AM
Top
Follow Us
