CRX Top Mount Downpipe
Old May 7, 2007 | 02:17 AM
mrchris1979's Avatar
Default CRX Top Mount Downpipe
I've just upgraded to a full 3" downpipe. Selling my downpipe from Boostwerks CRX topmount. It is stainless, 2.5" with flexpipe, two 02 bungs, 3 bolt flange and 4 bolt for the turbo. There is damage on the flex piece and just a scratch on the flange. No leaks from the flex, still works great. I bought it from Boostwerks in this condition and tested it myself. You can see actual install pics here https://honda-tech.com/zero...age=1. Check out the pics for the damage. A replacement piece is affordable if needed. I also cut off the support brakcet that he had on there as I found it not necessary and it was not aligning properly to my tranny. $100 for the downpipe. I will split the cost of shipping. Just PM me your zip code. The 3" stainless test pipe and the slip on adapter is also for sale. $50 The 3 bolt flange on the test it tig welded by Spoolin Performance. You can always add another flange for other set-ups. I had a muffler shop make me a simple 2.5" to 3" slip on pipe so I can use it with the downpipe temporarily. The band clamp, gaskets and bolts are also included and it works great with no leaks.
Downpipe $100 (click on pics to enlarge)
Test pipe set-up SOLD. SOLD. SOLD
Modified by mrchris1979 at 11:58 AM 5/14/2007
Old May 7, 2007 | 04:05 AM
Laserjock's Avatar
Default Re: CRX Top Mount Downpipe (mrchris1979)
what size is the pipe where it narrows down on the testpipe?
what size is the flange?
Old May 7, 2007 | 08:41 AM
Default Re: CRX Top Mount Downpipe (Laserjock)
If your asking about this end, it measures at about 1/16" less so 2 15/16 ". It's very sligthly tapered so if you decide to put a standard 3 bolt flange on it, or any other flange that has a 3" inner diameter, it slides right on the test pipe and sets it flush.
Old May 7, 2007 | 07:08 PM
Laserjock's Avatar
no, this one
Old May 8, 2007 | 01:57 AM
Total length of that piece is 6.5". The flange is 2.5" ID to a 2.5" pipe and then flares to a hair over 3" so it slips over the test pipe. Hope that helps.
Modified by mrchris1979 at 11:10 AM 5/8/2007
Old May 8, 2007 | 04:22 PM
Laserjock's Avatar
ok, that will work. pm me if you hav paypal
Old May 9, 2007 | 06:30 PM
PM sent.
Old May 14, 2007 | 02:59 AM
Test Pipe Set-Up is sold. Thanks Laserjock
BlueShadow
Aug 19, 2009 04:01 PM
Legion
Feb 22, 2008 05:30 PM
94TurboGSR
Sep 21, 2003 10:51 PM
BoostedH23a1
Apr 26, 2003 12:00 AM
W.Zero
Mar 12, 2003 09:58 PM
