best 18 tire???
Old May 6, 2007 | 10:02 PM
JDMJNKY's Avatar
Default best 18 tire???
Hey guys I'm gonna be buying some tires soon for the wifey's wheels & I want to know from anyone running 18's or up whats the best tire out there???
either size just looking for a good tire!
225/45/18 or 235/40/18
Old May 7, 2007 | 07:20 AM
JDMJNKY's Avatar
no input?
Old May 7, 2007 | 09:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: best 18 tire??? (JDMJNKY)
What car is this for (model, year, version)?
Old May 7, 2007 | 11:16 AM
JDMJNKY's Avatar
Default Re: best 18 tire??? (nsxtasy)
05 v6 accord sedan
Old May 7, 2007 | 01:03 PM
nsxtasy's Avatar
H-T Order of Merit
The proper size tire for your car is 215/45-18. The sizes you mentioned are too big.
The best "bang for the buck" tire in 215/45-18 is the Kumho SPT. It's $114/tire at the Tire Rack, but it's on back order. $120/tire including free shipping at Discount Tire Direct. Very good dry traction, excellent wet traction, lasts a reasonably long time (25-40K miles).
You can get even better tires (like the Michelin Pilot Sport) but they will cost a LOT more.
Old May 8, 2007 | 06:35 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The proper size tire for your car is 215/45-18. The sizes you mentioned are too big.
i'd like to go w/ a wider tire though? yeah we have michelins now 1 rotation going strong @ 48k
Old May 8, 2007 | 06:39 PM
JDMJNKY's Avatar
so is too fast better than too slow?
Old May 8, 2007 | 07:12 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">i'd like to go w/ a wider tire though?</TD></TR></TABLE>
There are a lot of downsides:
- They make your speedometer and odometer inaccurate
- They make your car accelerate slower in each gear (like getting taller gears)
- They might rub on the wheel wells
- They're usually more expensive
And there are no significant benefits.
If you're looking for more performance, concentrate on buying better tires, not wider tires.
If you really want better performance, get the Michelin Pilot Sport in 215/45-18 instead of the Kumho SPT. The Michelin is a significantly better tire, and the 215 Michelin will perform better than the SPT, even one in a wider size. However, there is one downside of the Pilot Sport. Or, rather, 311 downsides per tire.
Stick with the right size for your car. In 18", that's 215/45-18.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">so is too fast better than too slow?</TD></TR></TABLE>
If you don't want to make your car accelerate slower, get 215/45-18. If you want your car to accelerate slower, get bigger tires than that.
Old May 8, 2007 | 07:38 PM
JDMJNKY's Avatar
lol...word!
Old May 9, 2007 | 04:52 PM
JDMJNKY's Avatar
what do you think of 235/40/18 ????
Old May 9, 2007 | 07:29 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">what do you think of 235/40/18 ????</TD></TR></TABLE>
They will probably rub. Even though they're about the same outer diameter as 215/45-18, they're wider, and that's likely to be a problem for rubbing. (Tires have a good chance of rubbing whenever they're wider than 20 mm more than stock, and/or when they're more than about 2 percent larger in diameter than stock.)
Stick with 215/45-18.
Old May 9, 2007 | 07:56 PM
DaveSi677's Avatar
I agree with everything that nsxtasy mentioned! Seriously don't be like everybody around here lately and the wrong tire size! Get what is right!
Old May 11, 2007 | 04:44 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">They will probably rub. Even though they're about the same outer diameter as 215/45-18, they're wider, and that's likely to be a problem for rubbing. (Tires have a good chance of rubbing whenever they're wider than 20 mm more than stock, and/or when they're more than about 2 percent larger in diameter than stock.)
Stick with 215/45-18.</TD></TR></TABLE>
Actually its only a 1% diff. And I'm not droppin too much only 1.2 in front & 1.5 rear
Old May 11, 2007 | 04:51 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">Actually its only a 1% diff.</TD></TR></TABLE>
I know that. Did you read my post?
If you want to try them, go ahead. Just don't be surprised if they rub.
Old May 11, 2007 | 06:49 PM
JDMJNKY's Avatar
My buddy is running 225 on a rex minor rub no tire damage??? i think my accord has a bigger wheel well???? but i may just try them & see
Old May 12, 2007 | 03:00 PM
JDMJNKY's Avatar
Ok does anyone have the hook up on 215/45/18's I was quoted 180 a tire from any of the following michilen, Falken, & BF KDW
As for 225 40 18's I can get those for 420 a set?? Lmk ppl.
Old May 12, 2007 | 04:23 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">Ok does anyone have the hook up on 215/45/18's I was quoted 180 a tire from any of the following michilen, Falken, & BF KDW</TD></TR></TABLE>
Sounds like you really don't bother reading ANY posts here. Like, for example, this one:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">The best "bang for the buck" tire in 215/45-18 is the Kumho SPT</FONT>. It's $114/tire at the Tire Rack, but it's on back order. <FONT SIZE="4">$120/tire including free shipping at Discount Tire Direct.</FONT> Very good dry traction, excellent wet traction, lasts a reasonably long time (25-40K miles).</TD></TR></TABLE>
Their website is at www.discounttiredirect.com.
Old May 12, 2007 | 04:43 PM
JDMJNKY's Avatar
<FONT SIZE="8">i dont read......? you dont read I said michilen, BF or Falken! lol </FONT>
Old May 12, 2007 | 05:54 PM
nsxtasy's Avatar
H-T Order of Merit
It's very clear you don't want advice and you already know what you want to buy. You want to buy brands that cost a lot or wear fast, and you're not interested in the best "bang for the buck". Go right ahead. It's not my money...
Old May 12, 2007 | 07:53 PM
JDMJNKY's Avatar
dont mean to seem ignorant, I'd just like to make the most educated buy, that's all....anyone use Bridgestone Potenza RE960AS Pole Position???
Old May 13, 2007 | 06:38 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">anyone use Bridgestone Potenza RE960AS Pole Position???</TD></TR></TABLE>
The RE960AS is an all-season tire. All-season tires are designed for people who have to use the same tires in snow and bitter cold as they do in moderate to warm temperatures. If you often drive to Lake Tahoe to go skiing, the RE960AS might be a good choice. But if your tires are never going to see snow, like most folks in California, you're much better off with a summer tire, like the Kumho SPT (or the more expensive Michelin Pilot Sport or Michelin Pilot Exalto PE2). A good summer tire (like one of these) will give much better performance in moderate to warm temperatures than an all-season tire, on dry roads as well as in rain.
Old May 13, 2007 | 10:36 AM
JDMJNKY's Avatar
ok...thanx for the help, i think i can go on o make a decent decision on tire & size! NSXTASY
Old May 13, 2007 | 12:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (JDMJNKY)
redDAinteg
Apr 20, 2007 05:49 AM
JoeDaSoto
Feb 22, 2007 10:33 PM
Nameless Warrior
17
Nov 15, 2006 10:48 AM
94civicCx
Jun 2, 2006 06:16 PM
bemathew
21
Jun 27, 2004 04:36 PM
