Koni Yellow Problem on 95 Accord
Old May 6, 2007 | 09:56 PM
Riceintegrars's Avatar
Default Koni Yellow Problem on 95 Accord
Ok my friend has a 95 Accord 4dr EXR and we went to put some Koni Yellows on the car last night. Thing is, all the stock parts that are supposed to be used on the Koni's wont fit. The piston rod metal thing is thicker than the stock one.... is that supposed to be right? i was thought that this was supposed to be a pretty simply install with no modifying needed...
Old May 7, 2007 | 06:57 AM
TheMuffinMan's Avatar
He knows where you live!
I believe that's in the instructions that you need to do that.
You need to drill out the bump stop at least, I can't remember what all else had to be done.
Old May 7, 2007 | 10:54 AM
FDAccord's Avatar
you're supposed to cut the bumpstops, from what i remember mine fit perfectly.
Old May 7, 2007 | 12:09 PM
i know ur supposed to cut the bumpstops in half, but do i also have to drill out everything out aswell?? ei. metal washers ect.
Old May 7, 2007 | 12:30 PM
The Koni's should've come with some of those washers and what not, and you WILL have to drill out the bumpstop some.
ph0shizzle
Nov 2, 2006 07:06 AM
Seeds
May 25, 2006 11:43 AM
mike-y
Suspension & Brakes
May 6, 2006 05:34 PM
