Honda S2000 Honda S2000
Rolling Front Fenders??
Old May 6, 2007 | 07:33 PM
silentdancer's Avatar
Default Rolling Front Fenders??
w00t more clearance.
Modified by silentdancer at 9:39 PM 5/6/2007
Old May 6, 2007 | 08:06 PM
ITRbroham's Avatar
shit post warrior
Default Re: Rolling Front Fenders?? (silentdancer)
OK......so did you roll, pull, or do both to the front fenders?
Old May 6, 2007 | 08:29 PM
LAS2K's Avatar
Default Re: Rolling Front Fenders?? (ITRbroham)
eww it looks terrible...
jk TJ
Old May 6, 2007 | 08:40 PM
Default Re: Rolling Front Fenders?? (LAS2K)
fenders are rolled and pulled. so if you are rubbing in the front here is one of the solutions
Old May 6, 2007 | 09:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">eww it looks terrible...
jk TJ </TD></TR></TABLE>
Old May 6, 2007 | 09:40 PM
faster Type R's Avatar
did you use those professional rollers?
Old May 6, 2007 | 10:05 PM
Default Re: Rolling Front Fenders?? (faster Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faster Type R &raquo;</TD></TR><TR><TD CLASS="quote">did you use those professional rollers?</TD></TR></TABLE>
eastwood fender roller + heat gun
Old May 7, 2007 | 08:39 AM
Mr. Projekt's Avatar
* B A N N E D *
Does the plastic liner still bolt up?
Old May 7, 2007 | 07:34 PM
Default Re: Rolling Front Fenders?? (Mr. Projekt)
before you roll the fender, you unclip the top clips holding the fender liner in, and tuck the fender liner behind the little fender lip and then roll it.
Old May 7, 2007 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdancer &raquo;</TD></TR><TR><TD CLASS="quote">before you roll the fender, you unclip the top clips holding the fender liner in, and tuck the fender liner behind the little fender lip and then roll it.
do you clip the plastic liner after you roll the fender?
Old May 7, 2007 | 08:45 PM
Francesco's Avatar
i need more info man. post a pic from the inside of the fender, im doing this this weekend on my car.
Old May 7, 2007 | 08:58 PM
no, theres no room to fit the clips in once the fender is rolled in. the fender liner wont go anywhere once its tucked in.
Frank, ill try and get some better pics some time this week
Old May 7, 2007 | 09:21 PM
Francesco's Avatar
kool. im borrowing a roller this weekend. my fronts are 17x7.5 +45, so ill be ok with the 215/45's i ordered. i just have to run -2 front camber in a week or so once i have everything the way i want it. im tucked in the front.
Old May 9, 2007 | 12:09 AM
s2000 mf's Avatar
Looks good. I will be doing this soon.
Old May 9, 2007 | 06:20 AM
Damon Reeves's Avatar
Old May 10, 2007 | 11:34 AM
MestupS2K's Avatar
Did you use the same rolling tool for the "pulling" part as you did the initial rolling? Thanks
Old May 28, 2007 | 09:49 PM
JJ-Built's Avatar
Default Re: (MestupS2K)
any side shots of the car?
Old May 30, 2007 | 07:52 AM
tegsallgood's Avatar
Default Re: (JJ-Built)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ-Built &raquo;</TD></TR><TR><TD CLASS="quote">any side shots of the car?</TD></TR></TABLE>
yeah id like to see that too... that would bother the hell out of me tho, i couldnt deal with it looking like that. not that it looks bad or anything i just love that flush line...
Old May 31, 2007 | 07:10 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: (tegsallgood)
yeah whats pulling involve?
Old May 31, 2007 | 02:46 PM
spunkysandoval's Avatar
The fender rolling process and pulling process are the same. The same tool is used. The difference is how much outward force you apply to the fender. TJ's are a fairly extreme roll/pull.
Francesco, I don't think you will need to go this extreme on yours with your set up. In fact I think it may be detrimental to the overall look of the front stance because it will appear to have a lot of wheel gap. You should only require a slight pull plus a full roll of the fender lip.
Here are some pics from when I did silentdancer's rear fender.
and here's a pic of a mild pull on another car I did.
You can compare it to the pull on silent dancers and notice the difference.
His pull has tons of clearance so he can run plus size tires or low offset wide rims up front and be slammed. :D
Spunky
Old May 31, 2007 | 03:04 PM
Default Re: (spunkysandoval)
ok yeah thats how i did mine, just the angle on the wheel, how flush you make vertically, gotcha
ME=ADRIAN
May 14, 2007 10:43 AM
jerebear
Jan 10, 2007 06:40 PM
lyzer227
Dec 14, 2006 12:52 PM
De_tour
10
Apr 1, 2006 07:11 PM
boostin GSR
Honda Motorcycles
19
Jan 13, 2005 01:40 PM
