Si rear brakes on a DX
i don't know if you HAVE TO but it pretty easy to do the whole trailing arm.
https://honda-tech.com/zerothread?id=1916212
You do not have to swap the rear trailing arm you can just swap the hubs. However, I tried swapping just the hubs and gave up shortly after. Just swap the rear trailing arm and get the ebrake cable from a 90-91 integra (it's the only one that will fit a crx cable is to short).
wickedEFguy
Apr 22, 2010 12:19 PM
