mod availability
Old May 6, 2007 | 06:41 PM
gsr-2nr's Avatar
Default mod availability
my brother has a 06 type-s and looking for the basic bolt on's all you mostly see is 03-05 why is 06 excluded some fittment listings say 06 but some dont. I know the engine went mostly unchanged cept for hp rating, and exterior changed. Will the mods listed 02-05 fit?
Old May 6, 2007 | 07:46 PM
aznvietboi87's Avatar
Default Re: mod availability (gsr-2nr)
02-04 are different from the 05-06 rsx. it basically has everything the same except body style and some engine improvements here and there. most mods will fit both the 02-04 and 05+ rsx. but to be on the safe side just make you sure you get it for your car year. if the mod says it fits 02+ rsx then i will fit your bros car too. if it specifically says it only fits 02-04 rsx then it probably wont fit without some type of modification.
Old May 6, 2007 | 08:37 PM
whiteDCfiver's Avatar
If it says 05, tell your bro to mod away. 05's and 06's are the same.
Old May 6, 2007 | 09:24 PM
gsr-2nr's Avatar
Default Re: mod availability (whiteDCfiver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteDCfiver &raquo;</TD></TR><TR><TD CLASS="quote">If it says 05, tell your bro to mod away. 05's and 06's are the same.</TD></TR></TABLE>
I figured so, just wanted to double check before I tell him to go ahead and spend the money. Thanks
wicked krx
Jul 10, 2008 07:51 AM
flipsyde
11
Aug 25, 2007 02:51 PM
teknoracing
Acura TSX
12
Aug 23, 2007 04:09 AM
swlabhot
Nov 4, 2003 08:29 PM
